Dell Alienware 13 Touch pad Replacement
    1. Dell Alienware 13 Touch pad Replacement, Base Panel: step 1, image 1 of 1
      • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
      • Close the device and turn the device over.
      Ask FixBot
    2. Dell Alienware 13 Touch pad Replacement: step 2, image 1 of 1
      • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
      • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
      Ask FixBot
    3. Dell Alienware 13 Touch pad Replacement: step 3, image 1 of 3 Dell Alienware 13 Touch pad Replacement: step 3, image 2 of 3 Dell Alienware 13 Touch pad Replacement: step 3, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    1. Dell Alienware 13 Touch pad Replacement, Touch pad: step 4, image 1 of 2 Dell Alienware 13 Touch pad Replacement, Touch pad: step 4, image 2 of 2
      • Disconnect the battery cable from the battery cable terminal.
      Ask FixBot
    2. Dell Alienware 13 Touch pad Replacement: step 5, image 1 of 1
      • Remove (4) 6 mm Phillips head screws from the solid-state metal drive bracket, using a Phillips # 1 screwdriver.
      Ask FixBot
    3. Dell Alienware 13 Touch pad Replacement: step 6, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 6, image 2 of 2
      • Grab the pull tab to pivot the solid-state drive bracket upwards. Remove the bracket from the computer base.
      Ask FixBot
    4. Dell Alienware 13 Touch pad Replacement: step 7, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 7, image 2 of 2
      • Using the pull tab, disconnect the black solid-state drive cable from the system board.
      Ask FixBot
    5. Dell Alienware 13 Touch pad Replacement: step 8, image 1 of 1
      • Remove (2) 3 mm Phillips head screws, using a Phillips # 0 screwdriver, that connect the solid-state drive assembly to the computer base.
      Ask FixBot
    6. Dell Alienware 13 Touch pad Replacement: step 9, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 9, image 2 of 2
      • Lift up on the solid-state drive assembly to remove it from the computer base.
      Ask FixBot
    7. Dell Alienware 13 Touch pad Replacement: step 10, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 10, image 2 of 2
      • Locate two cables labeled, "KB Backlight" (orange) and "KB Membrane" (black). Lift up on the latches to disconnect the cables from the system board.
      Ask FixBot
    8. Dell Alienware 13 Touch pad Replacement: step 11, image 1 of 3 Dell Alienware 13 Touch pad Replacement: step 11, image 2 of 3 Dell Alienware 13 Touch pad Replacement: step 11, image 3 of 3
      • Remove (8) 9 mm Phillips head screws using a Phillips # 1 screwdriver, that secures the palm-rest assembly to the computer base.
      • Remove (4) 8 mm Phillips head screws using a Phillips # 1 screwdriver.
      • Remove (2) 7 mm Phillips head screws using a Phillips # 1 screwdriver.
      Ask FixBot
    9. Dell Alienware 13 Touch pad Replacement: step 12, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 12, image 2 of 2
      • Lift the computer base slightly towards you and push the release tabs on the palm-rest assembly until it pops out using a spudger.
      Ask FixBot
    10. Dell Alienware 13 Touch pad Replacement: step 13, image 1 of 3 Dell Alienware 13 Touch pad Replacement: step 13, image 2 of 3 Dell Alienware 13 Touch pad Replacement: step 13, image 3 of 3
      • Turn the computer over and open the display as far as possible.
      • Using a plastic spudger, pry up along the edges of the palm-rest assembly.
      • Gently lift the palm-rest assembly.
      Ask FixBot
    11. Dell Alienware 13 Touch pad Replacement: step 14, image 1 of 3 Dell Alienware 13 Touch pad Replacement: step 14, image 2 of 3 Dell Alienware 13 Touch pad Replacement: step 14, image 3 of 3
      • Lift the connector latch and disconnect the power-button board cable from the system board. Identified as a cable with a blue tab.
      • Lift the palm-rest assembly off the computer base.
      Ask FixBot
    12. Dell Alienware 13 Touch pad Replacement: step 15, image 1 of 2 Dell Alienware 13 Touch pad Replacement: step 15, image 2 of 2
      • Disconnect the touch pad cable from the touch pad.
      Ask FixBot
    13. Dell Alienware 13 Touch pad Replacement: step 16, image 1 of 3 Dell Alienware 13 Touch pad Replacement: step 16, image 2 of 3 Dell Alienware 13 Touch pad Replacement: step 16, image 3 of 3
      • Remove (4) 3 mm Phillips head screws securing the touch pad to the palm rest assembly using a Phillips # 0 screwdriver.
      • Lift up and remove the touch pad from the palm rest assembly.
      Ask FixBot
Adam Russell
898 Reputation
6 Guides authored
USF Tampa, Team 14-2, Eyestone Fall 2016 Member of USF Tampa, Team 14-2, Eyestone Fall 2016
USFT-EYESTONE-F16S14G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 99
All Time: 782
