Dell Alienware 13 R3 Touch Pad Replacement
    1. Dell Alienware 13 R3 Touch Pad Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Loosen the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Pry the Base Cover: step 2, image 1 of 1
      • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Lift the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 13 R3 Touch Pad Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
      • Using a plastic scribe, disconnect the battery cable from the system board.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Touch Pad Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
      Ask FixBot
    6. Dell Alienware 13 R3 Touch Pad Replacement, Tighten the Five Captive Screws: step 7, image 1 of 1
      • Tighten the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Align the Notch: step 8, image 1 of 1
      • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
      • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Lift the Wireless-Card Bracket: step 9, image 1 of 1
      • Lift the wireless-card bracket off the wireless card.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Disconnecting the Antenna Cables: step 10, image 1 of 1
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
      • Align the notch on the wireless card with the tab on the wireless-card slot.
      Ask FixBot
      • Slide the NEW wireless card at an angle into the wireless-card slot.
      Ask FixBot
      • Connect the antenna cables to the wireless card.
      Ask FixBot
    4. Dell Alienware 13 R3 Touch Pad Replacement, Align the Screw Hole: step 14, image 1 of 1
      • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
      Ask FixBot
    5. Dell Alienware 13 R3 Touch Pad Replacement, Replace the Screw: step 15, image 1 of 1
      • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Screw: step 16, image 1 of 1
      • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Lift and Slide the Solid-State Drive: step 17, image 1 of 1
      • Lift and slide the solid-state drive from the solid-state drive slot.
      Ask FixBot
      • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Press the Memory Module: step 19, image 1 of 1
      • Press the memory module down until it clicks into place.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Screws: step 20, image 1 of 1
      • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Using a Plastic Scribe: step 21, image 1 of 1
      • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
      Ask FixBot
      • Slide and remove the rear-I/O cover from the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Sliding the Rear-I/O: step 23, image 1 of 1
      • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
      Ask FixBot
      • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Screws: step 25, image 1 of 1
      • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Screw: step 26, image 1 of 1
      • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Two Screws: step 27, image 1 of 1
      • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Touch Pad Replacement, Lift the Computer Base: step 28, image 1 of 1
      • Lift the computer base from the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Touch Pad Replacement, Align the Screw Holes: step 29, image 1 of 1
      • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
      Ask FixBot
      • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Peeling the Keyboard Connector: step 33, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Lifting the Battery: step 34, image 1 of 1
      • Lift the battery off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Placing the New Battery: step 35, image 1 of 1
      • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
      • Using the alignment post, place the NEW battery on the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Touch Pad Replacement, Adhering the Keyboard: step 36, image 1 of 1
      • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Touch Pad Replacement, Open the Latches: step 37, image 1 of 1
      • Open the latches and disconnect the touch-pad cable from the system board and touch pad.
      Ask FixBot
    2. Dell Alienware 13 R3 Touch Pad Replacement, Peel off the Touch-Pad Cable: step 38, image 1 of 1
      • Peel off the touch-pad cable from the touch-pad bracket.
      Ask FixBot
    3. Dell Alienware 13 R3 Touch Pad Replacement, Disconnect the Touch-Pad Buttons Cable: step 39, image 1 of 1
      • Open the latch and disconnect the touch-pad buttons cable from the touch pad.
      Ask FixBot
    4. Dell Alienware 13 R3 Touch Pad Replacement, Remove the Screws: step 40, image 1 of 1
      • Remove the five screws (M2x3) that secure the touch-pad bracket to the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Touch Pad Replacement, Lift the Touch-Pad Bracket: step 41, image 1 of 1
      • Using a plastic scribe, lift the touch-pad bracket off the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 R3 Touch Pad Replacement, Lifting the Touch-Pad: step 42, image 1 of 1
      • Lift the touch pad off the palm-rest assembly.
      Ask FixBot
    7. Dell Alienware 13 R3 Touch Pad Replacement, Placing the Touch Pad: step 43, image 1 of 1
      • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the touch pad.
      • Using the alignment posts on the palm-rest assembly, place the NEW touch pad on the palm-rest assembly.
      Ask FixBot
    8. Dell Alienware 13 R3 Touch Pad Replacement, Align the Screw Holes: step 44, image 1 of 1
      • Align the screw holes on the touch-pad bracket with the screw holes on the palm-rest assembly.
      Ask FixBot
      • Replace the five screws (M2x3) that secure the touch-pad bracket to the palm-rest assembly.
      Ask FixBot
      • Slide the touch-pad buttons cable into the respective connector on the touch pad and close the latch to secure the cable.
      Ask FixBot
      • Slide the touch-pad cables into their respective connectors on the system board and touch pad, and close the latches to secure the cable.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 68
All Time: 1,476
