Dell Alienware 13 R3 Solid-State Drive Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
66
All Time:
1,123
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Solid-State Drive.
Tools
    1. Dell Alienware 13 R3 Solid-State Drive Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Loosen the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Solid-State Drive Replacement, Pry the Base Cover: step 2, image 1 of 1
      • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Solid-State Drive Replacement, Lift the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 13 R3 Solid-State Drive Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
      • Using a plastic scribe, disconnect the battery cable from the system board.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Solid-State Drive Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
      Ask FixBot
    6. Dell Alienware 13 R3 Solid-State Drive Replacement, Tighten the Five Captive Screws: step 7, image 1 of 1
      • Tighten the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Solid-State Drive Replacement, Remove the Screw: step 8, image 1 of 1
      • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Solid-State Drive Replacement, Lift and Slide the Solid-State Drive: step 9, image 1 of 1
      • Lift and slide the solid-state drive from the solid-state drive slot.
      Ask FixBot
      • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
      Ask FixBot
    3. Dell Alienware 13 R3 Solid-State Drive Replacement, Press the Memory Module: step 11, image 1 of 1
      • Press the memory module down until it clicks into place.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 66
All Time: 1,123
