Up to 20% off select tools
Dell Alienware 13 R3 Memory Modules Replacement
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
67
All Time:
1,012
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 6 - 30 minutes
Difficulty: Easy
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the memory module.
    1. Dell Alienware 13 R3 Memory Modules Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Loosen the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Memory Modules Replacement, Pry the Base Cover: step 2, image 1 of 1
      • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Memory Modules Replacement, Lift the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 13 R3 Memory Modules Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
      • Using a plastic scribe, disconnect the battery cable from the system board.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Memory Modules Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
      Ask FixBot
    6. Dell Alienware 13 R3 Memory Modules Replacement, Tighten the Five Captive Screws: step 7, image 1 of 1
      • Tighten the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Memory Modules Replacement, Popping up the Memory Module: step 8, image 1 of 1
      • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell Alienware 13 R3 Memory Modules Replacement, Remove the Memory Module: step 9, image 1 of 1
      • Slide and remove the memory module from the memory-module slot.
      Ask FixBot
      • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
      Ask FixBot
    3. Dell Alienware 13 R3 Memory Modules Replacement, Press the Memory Module Down: step 11, image 1 of 1
      • Press the memory module down until it clicks into place.
      Ask FixBot
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 67
All Time: 1,012
