Dell Alienware 13 R3 Keyboard Replacement
    1. Dell Alienware 13 R3 Keyboard Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Loosen the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Pry the Base Cover: step 2, image 1 of 1
      • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Lift the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
      • Using a plastic scribe, disconnect the battery cable from the system board.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
      Ask FixBot
    6. Dell Alienware 13 R3 Keyboard Replacement, Tighten the Five Captive Screws: step 7, image 1 of 1
      • Tighten the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Align the Notch: step 8, image 1 of 1
      • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
      • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Lift the Wireless-Card Bracket: step 9, image 1 of 1
      • Lift the wireless-card bracket off the wireless card.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Disconnecting the Antenna Cables: step 10, image 1 of 1
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
      • Align the notch on the wireless card with the tab on the wireless-card slot.
      Ask FixBot
      • Slide the NEW wireless card at an angle into the wireless-card slot.
      Ask FixBot
      • Connect the antenna cables to the wireless card.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Hole: step 14, image 1 of 1
      • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Replace the Screw: step 15, image 1 of 1
      • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screw: step 16, image 1 of 1
      • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Lift and Slide the Solid-State Drive: step 17, image 1 of 1
      • Lift and slide the solid-state drive from the solid-state drive slot.
      Ask FixBot
      • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Press the Memory Module: step 19, image 1 of 1
      • Press the memory module down until it clicks into place.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Popping up the Memory Module: step 20, image 1 of 1
      • Using your fingertips, carefully spread apart the securing clips on each end of the memory-module slot until the memory module pops up.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Remove the Memory Module: step 21, image 1 of 1
      • Slide and remove the memory module from the memory-module slot.
      Ask FixBot
      • Align the notch on the NEW memory module with the tab on the memory-module slot and slide the memory module firmly into the slot at an angle.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Press the Memory Module Down: step 23, image 1 of 1
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screws: step 24, image 1 of 1
      • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Using a Plastic Scribe: step 25, image 1 of 1
      • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
      Ask FixBot
      • Slide and remove the rear-I/O cover from the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Sliding the Rear-I/O: step 27, image 1 of 1
      • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
      Ask FixBot
      • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screws: step 29, image 1 of 1
      • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screw: step 30, image 1 of 1
      • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Remove the Two Screws: step 31, image 1 of 1
      • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Lift the Computer Base: step 32, image 1 of 1
      • Lift the computer base from the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Holes: step 33, image 1 of 1
      • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
      Ask FixBot
      • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Disconnecting the Coin-Cell Battery: step 37, image 1 of 1
      • CAUTION: Removing the coin-cell battery resets the BIOS setup program’s settings to default. It is recommended that you note the BIOS setup program’s settings before removing the coin-cell battery.
      • Disconnect the coin-cell battery cable from the system board.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Peeling the Coin-Cell Battery: step 38, image 1 of 1
      • Gently peel off the coin-cell battery along with its cable off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Adhere the Coin-Cell Battery: step 39, image 1 of 1
      • Adhere the NEW coin-cell battery to the palm-rest assembly.
      Ask FixBot
      • Connect the coin-cell battery cable to the system board.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Disconnect the Left-Fan Cable: step 41, image 1 of 1
      • WARNING: The heat sink may become hot during normal operation. Allow sufficient time for the heat sink to cool before you touch it.
      • CAUTION: For maximum cooling of the processor, do not touch the heat transfer areas on the heat sink. The oils in your skin can reduce the heat transfer capability of the thermal grease.
      • Disconnect the left-fan cable from the system board.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Disconnecting the Right-Fan Cable: step 42, image 1 of 1
      • Disconnect the right-fan cable from the system board.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Remove the Seven Screws: step 43, image 1 of 1
      • In sequential order (as indicated on the heat-sink assembly), remove the seven screws (M2x3) that secure the heat-sink assembly to the system board.
      Ask FixBot
      • Lift the heat-sink assembly off the system board.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Holes: step 45, image 1 of 1
      • CAUTION: Incorrect alignment of the heat sink can damage the system board and processor.
      • NOTE: The original thermal grease can be reused if the original system board and fan are reinstalled together. If either the system board or the fan is replaced, use the thermal pad provided in the kit to ensure that thermal conductivity is achieved.
      • Align the screw holes on the NEW heat-sink assembly with the screw holes on the system board.
      Ask FixBot
      • In sequential order (indicated on the heat-sink assembly), replace the seven screws (M2x3) that secure the heat-sink assembly to the system board.
      Ask FixBot
      • Connect the right-fan cable to the respective connector on the system board.
      Ask FixBot
      • Connect the left-fan cable to the respective connector on the system board.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Peeling the Keyboard Connector: step 49, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Lifting the Battery: step 50, image 1 of 1
      • Lift the battery off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Placing the New Battery: step 51, image 1 of 1
      • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
      • Using the alignment post, place the NEW battery on the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Adhering the Keyboard: step 52, image 1 of 1
      • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Turn the Computer Over: step 53, image 1 of 1
      • NOTE: Your computer’s Service Tag is stored in the system board. You must enter the Service Tag in the BIOS setup program after you replace the system board.
      • NOTE: Replacing the system board removes any changes you have made to the BIOS using the BIOS setup program. You must make the appropriate changes again after you replace the system board.
      • NOTE: Before disconnecting the cables from the system board, note the location of the connectors so that you can reconnect the cables correctly after you replace the system board.
      • CAUTION: Place the computer on a clean, flat surface.
      • Turn the computer over.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Disconnecting the Logo-Board Cable: step 54, image 1 of 1
      • Disconnect the logo-board cable from the system board.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Disconnecting the Power-Button Board Cable: step 55, image 1 of 1
      • Using the pull-tab, disconnect the power-button board cable from the system board.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Open the Latch: step 56, image 1 of 1
      • Open the latch and disconnect the display cable from the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Turn the Computer Over: step 57, image 1 of 1
      Ask FixBot
    6. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screw: step 58, image 1 of 1
      • Remove the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board and lift the USB Type-C port bracket off the system board.
      Ask FixBot
      • Disconnect the power-adapter port cable from the system board.
      Ask FixBot
    7. Dell Alienware 13 R3 Keyboard Replacement, Disconnect the Speaker Cable: step 60, image 1 of 1
      • Disconnect the speaker cable from the system board.
      Ask FixBot
    8. Dell Alienware 13 R3 Keyboard Replacement, Open the Latch: step 61, image 1 of 1
      • Open the latch and disconnect the keyboard cable from the system board.
      Ask FixBot
    9. Dell Alienware 13 R3 Keyboard Replacement, Open the Latch: step 62, image 1 of 1
      • Open the latch and disconnect the keyboard-backlight cable from the system board.
      Ask FixBot
    10. Dell Alienware 13 R3 Keyboard Replacement, Disconnect the Touch-Pad Cable: step 63, image 1 of 1
      • Open the latch and disconnect the touch-pad cable from the system board.
      Ask FixBot
    11. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screw: step 64, image 1 of 1
      Ask FixBot
    12. Dell Alienware 13 R3 Keyboard Replacement, Remove the two Screws: step 65, image 1 of 1
      • Remove the two screws (M2.5x6L) that secure the system board to the palm- rest assembly.
      Ask FixBot
    13. Dell Alienware 13 R3 Keyboard Replacement, Lift the System Board: step 66, image 1 of 1
      • Lift the system board off the palm-rest assembly.
      Ask FixBot
    14. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Holes: step 67, image 1 of 1
      • CAUTION: Ensure that no cables are under the system board.
      • Align the screw holes on the NEW system board with the screw holes on the palm- rest assembly.
      Ask FixBot
    15. Dell Alienware 13 R3 Keyboard Replacement, Replace the Two Screws: step 68, image 1 of 1
      • Replace the two screws (M2.5x6L) that secure the system-board to the palm- rest assembly.
      Ask FixBot
    16. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Hole: step 69, image 1 of 1
      • Align the screw hole on the USB Type-C port bracket with the screw hole on the system board on the back and right side of your computer.
      Ask FixBot
    17. Dell Alienware 13 R3 Keyboard Replacement, Replace the Screw: step 70, image 1 of 1
      • Replace the screw (M2.5x6L) that secures the USB Type-C port bracket to the system board on the back and right side of your computer.
      Ask FixBot
      • Slide the touch-pad cable into the connector on the system board and close the latch to secure the cable.
      Ask FixBot
    18. Dell Alienware 13 R3 Keyboard Replacement, Sliding the Keyboard-Backlight: step 72, image 1 of 1
      • Slide the keyboard-backlight cable into the connector on the system board and close the latch to secure the cable.
      Ask FixBot
    19. Dell Alienware 13 R3 Keyboard Replacement, Slide the Keyboard Cable: step 73, image 1 of 1
      • Slide the keyboard cable into the connector on the system board and close the latch to secure the cable.
      Ask FixBot
      • Connect the speaker cable to the system board.
      Ask FixBot
      • Connect the power-adapter port cable to the system board.
      Ask FixBot
    20. Dell Alienware 13 R3 Keyboard Replacement, Turn the Computer Over: step 76, image 1 of 1
      Ask FixBot
      • Slide the display cable into the connector on the system board and close the latch to secure the cable.
      Ask FixBot
      • Connect the power-button board cable to the system board.
      Ask FixBot
      • Connect the logo-board cable to the system board.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Screw: step 80, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Lift the Speaker: step 81, image 1 of 1
      • Lift the left speaker off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Peel off the Tape: step 82, image 1 of 1
      • Peel off the tape that secures the speaker cable to the palm-rest assembly.
      Ask FixBot
      • Remove the speaker cable from the routing guides on the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Lift the Right Speaker: step 84, image 1 of 1
      • Lift the right speaker off the palm-rest assembly.
      Ask FixBot
      • Using the alignment posts, place the NEW right speaker on the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Route the Speaker Cable: step 86, image 1 of 1
      • Route the speaker cable through the routing guides on palm-rest assembly.
      • NOTE: Move the keyboard and keyboard-backlit cables out of the way.
      Ask FixBot
    6. Dell Alienware 13 R3 Keyboard Replacement, Placing the Left Speaker: step 87, image 1 of 1
      • Using the alignment posts, place the NEW left speaker on the palm-rest assembly.
      Ask FixBot
      • Adhere the tape that secures the speaker cable to the palm-rest assembly.
      Ask FixBot
    7. Dell Alienware 13 R3 Keyboard Replacement, Replace the Screw: step 89, image 1 of 1
      • Replace the screw (M2x3) that secures the speaker to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Two Screws: step 90, image 1 of 1
      • Remove the two screws (M2x3) that secure the power-button board to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Lifting the Power-Button Board: step 91, image 1 of 1
      • Lift the power-button board, along with its cable, off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Peeling the Power-Button Board Cable: step 92, image 1 of 1
      • Peel the power-button board cable from the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Placing the New Power-Button Board: step 93, image 1 of 1
      • Using the alignment posts, place the NEW power-button board on the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Adhere the Power-Button Board Cable: step 94, image 1 of 1
      • Adhere the power-button board cable to the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Holes: step 95, image 1 of 1
      • Align the screw holes on the power-button board with the screw holes on the palm-rest assembly.
      Ask FixBot
    7. Dell Alienware 13 R3 Keyboard Replacement, Replace the Two Screws: step 96, image 1 of 1
      • Replace the two screws (M2x3) that secure the power-button board to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Keyboard Replacement, Remove the Eight Screws: step 97, image 1 of 1
      • Remove the eight screws (M2x3) that secure the keyboard bracket to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Keyboard Replacement, Prying the Keyboard Bracket: step 98, image 1 of 1
      • Using a plastic scribe, pry the keyboard bracket off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Keyboard Replacement, Lifting the Keyboard Bracket: step 99, image 1 of 1
      • Lift the keyboard bracket off the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Keyboard Replacement, Lifitng the Keyboard: step 100, image 1 of 1
      • Lift the keyboard at an angle and remove it from the tabs on the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Keyboard Replacement, Insert the Tabs: step 101, image 1 of 1
      • CAUTION: To avoid damaging the keyboard, do not place any cables under it.
      • Insert the tabs on the keyboard into the slots on the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 R3 Keyboard Replacement, Align the Tabs: step 102, image 1 of 1
      • Align the tabs on the palm-rest assembly to the slots on the keyboard bracket and snap into place.
      Ask FixBot
    7. Dell Alienware 13 R3 Keyboard Replacement, Align the Screw Holes: step 103, image 1 of 1
      • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
      Ask FixBot
    8. Dell Alienware 13 R3 Keyboard Replacement, Replace the Eight Screws: step 104, image 1 of 1
      • Replace the eight screws (M2x3) that secure the keyboard bracket to the palm-rest assembly.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 77
All Time: 2,661
