Dell Alienware 13 R3 Battery Replacement
    1. Dell Alienware 13 R3 Battery Replacement, Loosen the Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Loosen the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Pry the Base Cover: step 2, image 1 of 1
      • Using a plastic scribe, gently pry the base cover to release the tabs on the base cover from the slots on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Lift the Base Cover: step 3, image 1 of 1
      • Lift the base cover off the computer base.
      Ask FixBot
    4. Dell Alienware 13 R3 Battery Replacement, Disconnect the Battery Cable: step 4, image 1 of 1
      • Using a plastic scribe, disconnect the battery cable from the system board.
      Ask FixBot
      • Press and hold the power button for five seconds to ground the system board.
      Ask FixBot
    5. Dell Alienware 13 R3 Battery Replacement, Slide the Tabs: step 6, image 1 of 1
      • Slide the tabs on the NEW base cover into the slots on the computer base and snap the base cover into place
      Ask FixBot
    6. Dell Alienware 13 R3 Battery Replacement, Tighten the Five Captive Screws: step 7, image 1 of 1
      • Tighten the five captive screws that secure the base cover to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Battery Replacement, Align the Notch: step 8, image 1 of 1
      • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
      • Remove the screw (M2x3) that secures the wireless card and bracket to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Lift the Wireless-Card Bracket: step 9, image 1 of 1
      • Lift the wireless-card bracket off the wireless card.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Disconnecting the Antenna Cables: step 10, image 1 of 1
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
      • Align the notch on the wireless card with the tab on the wireless-card slot.
      Ask FixBot
      • Slide the NEW wireless card at an angle into the wireless-card slot.
      Ask FixBot
      • Connect the antenna cables to the wireless card.
      Ask FixBot
    4. Dell Alienware 13 R3 Battery Replacement, Align the Screw Hole: step 14, image 1 of 1
      • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card and the computer base.
      Ask FixBot
    5. Dell Alienware 13 R3 Battery Replacement, Replace the Screw: step 15, image 1 of 1
      • Replace the screw (M2x3) that secures the wireless-card bracket to the wireless card and the computer base.
      Ask FixBot
    1. Dell Alienware 13 R3 Battery Replacement, Remove the Screw: step 16, image 1 of 1
      • Remove the screw (M2x3) that secures the solid-state drive to the computer base.
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Lift and Slide the Solid-State Drive: step 17, image 1 of 1
      • Lift and slide the solid-state drive from the solid-state drive slot.
      Ask FixBot
      • Align the notch on the NEW solid-state drive with the tab on the solid-state drive slot and slide the solid-state drive into the solid-state drive slot.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Press the Memory Module: step 19, image 1 of 1
      • Press the memory module down until it clicks into place.
      Ask FixBot
    1. Dell Alienware 13 R3 Battery Replacement, Remove the Screws: step 20, image 1 of 1
      • Remove the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Using a Plastic Scribe: step 21, image 1 of 1
      • Using a plastic scribe, gently release the tabs that secure rear-I/O cover to the computer base.
      Ask FixBot
      • Slide and remove the rear-I/O cover from the computer base.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Sliding the Rear-I/O: step 23, image 1 of 1
      • Slide the NEW rear-I/O cover into the slots on the computer base and snap the rear-I/O cover into place.
      Ask FixBot
      • Replace the two screws (M2.5x6L) that secure the rear-I/O cover to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Battery Replacement, Remove the Screws: step 25, image 1 of 1
      • Remove the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Remove the Screw: step 26, image 1 of 1
      • Remove the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Remove the Two Screws: step 27, image 1 of 1
      • Remove the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Battery Replacement, Lift the Computer Base: step 28, image 1 of 1
      • Lift the computer base from the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R3 Battery Replacement, Align the Screw Holes: step 29, image 1 of 1
      • Align the screw holes on the NEW computer base with the screw holes on the palm-rest assembly.
      Ask FixBot
      • Replace the two (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the (M2x3) screw that secures the computer base to the palm-rest assembly.
      Ask FixBot
      • Replace the eleven (M2.5x6L) screws that secure the computer base to the palm-rest assembly.
      Ask FixBot
    1. Dell Alienware 13 R3 Battery Replacement, Peeling the Keyboard Connector: step 33, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 R3 Battery Replacement, Lifting the Battery: step 34, image 1 of 1
      • Lift the battery off the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R3 Battery Replacement, Placing the New Battery: step 35, image 1 of 1
      • CAUTION: Ensure the keyboard and keyboard-backlit cables are not under the battery.
      • Using the alignment post, place the NEW battery on the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R3 Battery Replacement, Adhering the Keyboard: step 36, image 1 of 1
      • Adhere the keyboard connector that secures the battery to the palm-rest assembly.
      Ask FixBot
2 other people completed this guide.
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
7 Guide Comments
Hello Terrence15 Thanks!, I was wondering if you could please Link or include the part name or comercial name, I mean the exact battery to know about it before opening the laptop. Thanks again very much!
Guido Ronconi - Reply Share
I was able to source a battery on Amazon, though it looks like Newegg and other online retailers have them as well. I was unable to find an OEM part number on Dell's website, but the OEM battery I removed has the following specs:
Model: TDW5P
Capacity: 76Wh (4802mAh)
Voltage: 15.2v (limit 17.84v)
Sean McAlister - Reply Share
If you are attempting this repair with little to no prior computer repair experience, read the guide thoroughly but be aware of the following:
This guide is an amalgam of other guides that make up the necessary steps, due to this some steps are out of order. (cont, in reply)
Do not reconnect the battery after pressing the power button, the reason we do this is to avoid shorting anything and reconnecting the battery would make this possible again.
There is no need to remove your memory modules are they do not impede removing the cover. However. you must remove both the wireless card and any installed M.2 SSDs as they are mounted to the cover.
When removing the wireless card there may be a small tab of foam tape holding it down, the only thing that actually holds the card in place is the bracket and screw. The card will stand up in the slot when you reinstall it, this is normal.
The first part you should be reinstalling is the last one you remove, the battery (again, do not connect the cable till the end of the repair, right before closing the computer up). Each part is then reinstalled in reverse order.
when installing the wireless card take care to attach the antennae in the original positions, check the images provided in the guide. Each antenna wire should slightly click into place, if it doesn't come loose with a gentle prod with a scribe it's in place.
Thanks @okura94 I am attempting this replacement next week hopefully when I get the Battery...
Past 24 Hours: 11
Past 7 Days: 27
Past 30 Days: 124
All Time: 10,736
