Dell Alienware 13 R2 Touch Pad Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
61
All Time:
713
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 2 hours
Difficulty: Moderate
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the touch pad.
Tools
    1. Dell Alienware 13 R2 Touch Pad Replacement, Turning Over the PC: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer After working inside your computer, follow the instructions in After Working Inside Your Computer For more safety best practices, see the regulatory compliance home page.
      • Close the display and turn the computer over.
      Ask FixBot
    2. Dell Alienware 13 R2 Touch Pad Replacement, Loosen the screws: step 2, image 1 of 1
      • Loosen the captive screws that secure the base panel to the computer base.
      Ask FixBot
    3. Dell Alienware 13 R2 Touch Pad Replacement, Releasing the Tabs: step 3, image 1 of 1
      • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
      Ask FixBot
    4. Dell Alienware 13 R2 Touch Pad Replacement, Disconnecting the Battery Cable: step 4, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Disconnecting the Battery Cable: step 4, image 2 of 2
      • Disconnect the battery cable from the battery-cable connector.
      • Turn the computer over.
      Ask FixBot
    5. Dell Alienware 13 R2 Touch Pad Replacement, Power Button: step 5, image 1 of 1
      • Press and hold the power button for 5 seconds to ground the system board.
      Ask FixBot
      • Connect the battery cable to the battery-cable connector.
      Ask FixBot
    6. Dell Alienware 13 R2 Touch Pad Replacement, Aligning the tabs: step 7, image 1 of 1
      • Align the tabs on the base panel with the slots on the computer base and snap the base panel into place.
      Ask FixBot
    7. Dell Alienware 13 R2 Touch Pad Replacement, Tighten the screws: step 8, image 1 of 1
      • Tighten the captive screws that secure the base panel to the computer base.
      Ask FixBot
    1. Dell Alienware 13 R2 Touch Pad Replacement, Removing the Screws: step 9, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Removing the Screws: step 9, image 2 of 2
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Remove the screws that secure the solid-state drive bracket to the solid-state drive assembly.
      Ask FixBot
    2. Dell Alienware 13 R2 Touch Pad Replacement, Peel off Computer Base Tabs: step 10, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Peel off Computer Base Tabs: step 10, image 2 of 2
      • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
      Ask FixBot
    3. Dell Alienware 13 R2 Touch Pad Replacement, Disconnecting the Solid-State Drive Cable: step 11, image 1 of 1
      • Using the pull tab, disconnect the solid-state drive cable from the system board.
      Ask FixBot
    4. Dell Alienware 13 R2 Touch Pad Replacement, Removing the Solid-State Drive: step 12, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Removing the Solid-State Drive: step 12, image 2 of 2
      • Remove the screws that secure the solid-state drive assembly to the computer base.
      Ask FixBot
    5. Dell Alienware 13 R2 Touch Pad Replacement, Lifting the Solid-State Assembly: step 13, image 1 of 1
      • Lift the solid-state drive assembly off the computer base.
      Ask FixBot
    6. Dell Alienware 13 R2 Touch Pad Replacement, Remove the Screw: step 14, image 1 of 1
      • Remove the screw that secures the solid-state drive to the solid-state drive assembly.
      Ask FixBot
    7. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Solid-State Assembly.: step 15, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Lift the Solid-State Assembly.: step 15, image 2 of 2
      • Slide and lift the solid-state drive off the solid-state drive assembly.
      Ask FixBot
    8. Dell Alienware 13 R2 Touch Pad Replacement, The New Solid-State Drive: step 16, image 1 of 1
      • Slide the NEW solid-state drive into the slot on the solid-state drive assembly.
      Ask FixBot
    9. Dell Alienware 13 R2 Touch Pad Replacement, Screw Replacement: step 17, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Screw Replacement: step 17, image 2 of 2
      • Replace the screw that secures the solid-state drive to the solid-state drive assembly.
      Ask FixBot
    10. Dell Alienware 13 R2 Touch Pad Replacement, Align the Screws: step 18, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Align the Screws: step 18, image 2 of 2
      • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
      Ask FixBot
    11. Dell Alienware 13 R2 Touch Pad Replacement, Replace the Screws: step 19, image 1 of 1
      • Replace the screws that secure the solid-state drive assembly to the computer base.
      Ask FixBot
    12. Dell Alienware 13 R2 Touch Pad Replacement, Connect the Cable to the System Board: step 20, image 1 of 1
      • Connect the solid-state drive cable to the system board.
      Ask FixBot
    13. Dell Alienware 13 R2 Touch Pad Replacement, Align the Screw Holes: step 21, image 1 of 1
      • Align the screw holes on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
      Ask FixBot
    14. Dell Alienware 13 R2 Touch Pad Replacement, Replace the Screws: step 22, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Replace the Screws: step 22, image 2 of 2
      • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
      Ask FixBot
    1. Dell Alienware 13 R2 Touch Pad Replacement, Lifting the Latches: step 23, image 1 of 1
      • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board.
      Ask FixBot
    2. Dell Alienware 13 R2 Touch Pad Replacement, Remove the Screws: step 24, image 1 of 1
      • Remove the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
    3. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Computer Base: step 25, image 1 of 1
      • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
      Ask FixBot
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    4. Dell Alienware 13 R2 Touch Pad Replacement, Prying the Palm-Rest Assembly: step 27, image 1 of 1
      • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Palm-Rest Assembly: step 28, image 1 of 1
      • Gently lift the palm-rest assembly and turn it over.
      Ask FixBot
    6. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Connector Latch: step 29, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Lift the Connector Latch: step 29, image 2 of 2
      • Lift the connector latch and disconnect the power-button board cable from the system board.
      Ask FixBot
    7. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Palm-Rest Assembly: step 30, image 1 of 1
      • Lift the palm-rest assembly off the computer base.
      Ask FixBot
    8. Dell Alienware 13 R2 Touch Pad Replacement, Removing: step 31, image 1 of 1
      • Remove the keyboard.
      • Remove the power-button board.
      • Remove the status-light board.
      • Remove the Touchpad.
      Ask FixBot
      • Replace the touchpad.
      • Replace the status-light board.
      • Replace the power-button board.
      • Replace the keyboard.
      Ask FixBot
      • Connect the power-button board cable to the system board.
      Ask FixBot
    9. Dell Alienware 13 R2 Touch Pad Replacement, Align the Palm-Rest Assembly: step 34, image 1 of 1
      • Align the palm-rest assembly on the computer base and snap it into place.
      Ask FixBot
      Ask FixBot
      • Replace the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
      • Connect the keyboard cable and the keyboard-backlight cable to the system board.
      Ask FixBot
    1. Ask FixBot
    2. Dell Alienware 13 R2 Touch Pad Replacement, Remove the Screws: step 39, image 1 of 2 Dell Alienware 13 R2 Touch Pad Replacement, Remove the Screws: step 39, image 2 of 2
      • Remove the screws that secure the touchpad to the palm-rest assembly.
      Ask FixBot
    3. Dell Alienware 13 R2 Touch Pad Replacement, Lift the Touchpad: step 40, image 1 of 1
      • Lift the touchpad off the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 R2 Touch Pad Replacement, Align the Screw Holes: step 41, image 1 of 1
      • Align the screw holes on the touchpad with the screw holes on the palm-rest assembly.
      Ask FixBot
      • Replace the screws that secure the touchpad to the palm-rest assembly.
      Ask FixBot
      • Slide the touchpad cable into the touchpad connector and press down the latch to secure the cable.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 61
All Time: 713
