Dell Alienware 13 Palm Rest Replacement
    1. Dell Alienware 13 Palm Rest Replacement, Base Panel: step 1, image 1 of 1
      • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
      • Close the device and turn the device over.
      Ask FixBot
    2. Dell Alienware 13 Palm Rest Replacement: step 2, image 1 of 1
      • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
      • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
      Ask FixBot
    3. Dell Alienware 13 Palm Rest Replacement: step 3, image 1 of 3 Dell Alienware 13 Palm Rest Replacement: step 3, image 2 of 3 Dell Alienware 13 Palm Rest Replacement: step 3, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
    1. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Keyboard: step 4, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
      Ask FixBot
    2. Dell Alienware 13 Palm Rest Replacement, Removing the Screws: step 5, image 1 of 2 Dell Alienware 13 Palm Rest Replacement, Removing the Screws: step 5, image 2 of 2
      • Remove the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
    3. Dell Alienware 13 Palm Rest Replacement, Popping out the Palm-Rest Assembly: step 6, image 1 of 1
      • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
      Ask FixBot
    4. Dell Alienware 13 Palm Rest Replacement, Turn the Computer Over: step 7, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    5. Dell Alienware 13 Palm Rest Replacement, Prying the Edges: step 8, image 1 of 1
      • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 Palm Rest Replacement, Lifting the Palm-Rest Assembly: step 9, image 1 of 1
      • Gently lift the palm-rest assembly and turn it over.
      Ask FixBot
    7. Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: step 10, image 1 of 2 Dell Alienware 13 Palm Rest Replacement, Disconnecting the Power-Board Cable: step 10, image 2 of 2
      • Lift the connector latch and disconnect the power-button board cable from the system board.
      Ask FixBot
      • Remove the Keyboard.
      • Remove the power-button board.
      • Remove the status-light board.
      • Remove the touchpad.
      Ask FixBot
      • Replace the touchpad.
      • Replace the status-light board.
      • Replace the power-button board.
      • Replace the keyboard.
      Ask FixBot
    8. Dell Alienware 13 Palm Rest Replacement, Connecting the Power-Button Board Cable: step 13, image 1 of 1
      • Connect the power-button board cable to the system board.
      Ask FixBot
    9. Dell Alienware 13 Palm Rest Replacement, Aligning the Palm-Rest Assembly.: step 14, image 1 of 1
      • Align the palm-rest assembly on the computer base and snap it into place.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
      • Replace the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
      • Connect the keyboard cable and the keyboard-backlight cable to the system board.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 101
All Time: 729
