Dell Alienware 13 Display Back-Cover Replacement
    1. Dell Alienware 13 Display Back-Cover Replacement, Base Panel: step 1, image 1 of 1
      • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
      • Close the device and turn the device over.
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement: step 2, image 1 of 1
      • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
      • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement: step 3, image 1 of 3 Dell Alienware 13 Display Back-Cover Replacement: step 3, image 2 of 3 Dell Alienware 13 Display Back-Cover Replacement: step 3, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
      • CAUTION: Solid-state drives are fragile. Exercise care when handling the hard drive.
      • CAUTION: To avoid data loss, do not remove the solid-state drive while the computer is in sleep or on state.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Pull Tab: step 5, image 1 of 1
      • Using the pull tab, pivot the solid-state drive bracket and peel off the bracket from the tabs on the computer base.
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the State Drive: step 6, image 1 of 1
      • Using the pull tab, disconnect the solid-state drive cable from the system board.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Remove Screws: step 7, image 1 of 1
      • Remove the screws that secure the solid-state drive assembly to the computer base.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Solid-State Drive Assembly Lift: step 8, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Solid-State Drive Assembly Lift: step 8, image 2 of 2
      • Lift the solid-state drive assembly off the computer base.
      • Make sure the screws are off the solid-state assembly.
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Slide and Lift: step 9, image 1 of 1
      • Slide and lift the solid-state drive off the solid-state assembly.
      Ask FixBot
    6. Dell Alienware 13 Display Back-Cover Replacement, Replacing the Solid-State Drive: step 10, image 1 of 1
      • Slide the new solid-state drive into the solid-state drive assembly.
      Ask FixBot
    7. Dell Alienware 13 Display Back-Cover Replacement, Replace the Screw: step 11, image 1 of 1
      • Replace the screw that secures the solid-state drive assembly with the screw holes on the computer base.
      Ask FixBot
    8. Dell Alienware 13 Display Back-Cover Replacement, Screw Align: step 12, image 1 of 1
      • Align the screw holes on the solid-state drive assembly with the screw holes on the computer base.
      Ask FixBot
    9. Dell Alienware 13 Display Back-Cover Replacement, Screw Replacement: step 13, image 1 of 1
      • Replace the screws that secure the solid-state drive assembly to the computer base.
      Ask FixBot
    10. Dell Alienware 13 Display Back-Cover Replacement, Connecting the Drive: step 14, image 1 of 1
      • Connect the solid-state drive cable to the system board.
      Ask FixBot
    11. Dell Alienware 13 Display Back-Cover Replacement, Aligning Screws: step 15, image 1 of 1
      • Align the screws on the solid-state drive bracket with the screw holes on the solid-state drive assembly.
      Ask FixBot
    12. Dell Alienware 13 Display Back-Cover Replacement, Replacing Screws: step 16, image 1 of 1
      • Replace the screws that secure the solid-state drive bracket to the solid-state drive assembly.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Keyboard: step 17, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Lift the latches and disconnect the keyboard and keyboard-backlight cables from the system board
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Removing the Screws: step 18, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Removing the Screws: step 18, image 2 of 2
      • Remove the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Popping out the Palm-Rest Assembly: step 19, image 1 of 1
      • Lift the computer base slightly and push the release tabs on the palm-rest assembly until it pops out.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Turn the Computer Over: step 20, image 1 of 1
      • Turn the computer over and open the display as far as possible.
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Prying the Edges: step 21, image 1 of 1
      • Using a plastic scribe, pry up along the edges of the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 Display Back-Cover Replacement, Lifting the Palm-Rest Assembly: step 22, image 1 of 1
      • Gently lift the palm-rest assembly and turn it over.
      Ask FixBot
    7. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Power-Board Cable: step 23, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Power-Board Cable: step 23, image 2 of 2
      • Lift the connector latch and disconnect the power-button board cable from the system board.
      Ask FixBot
      • Remove the Keyboard.
      • Remove the power-button board.
      • Remove the status-light board.
      • Remove the touchpad.
      Ask FixBot
      • Replace the touchpad.
      • Replace the status-light board.
      • Replace the power-button board.
      • Replace the keyboard.
      Ask FixBot
    8. Dell Alienware 13 Display Back-Cover Replacement, Connecting the Power-Button Board Cable: step 26, image 1 of 1
      • Connect the power-button board cable to the system board.
      Ask FixBot
    9. Dell Alienware 13 Display Back-Cover Replacement, Aligning the Palm-Rest Assembly.: step 27, image 1 of 1
      • Align the palm-rest assembly on the computer base and snap it into place.
      Ask FixBot
      • Close the display and turn the computer over.
      Ask FixBot
      • Replace the screws that secure the palm-rest assembly to the computer base.
      Ask FixBot
      • Connect the keyboard cable and the keyboard-backlight cable to the system board.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Open the Display: step 31, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Removing the Screws: step 32, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Removing the Screws: step 32, image 2 of 2
      • Remove the screws that secure the hinge caps to the display hinges.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Lift the Hinge Caps: step 33, image 1 of 1
      • Slide and lift the hinge caps off the display hinges.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Close the Display: step 34, image 1 of 1
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Peeling the Adhesive Tape: step 35, image 1 of 1
      • Peel off the adhesive tape from the wireless card.
      Ask FixBot
    6. Dell Alienware 13 Display Back-Cover Replacement, Remove the Screw: step 36, image 1 of 1
      • Remove the screw that secures the wireless-card bracket to the wireless card.
      Ask FixBot
    7. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Antenna Cables: step 37, image 1 of 1
      • Disconnect the antenna cables from the wireless card.
      Ask FixBot
      • Turn the computer over and open the display.
      Ask FixBot
    8. Dell Alienware 13 Display Back-Cover Replacement, Peeling the Adhesive Tapes: step 39, image 1 of 1
      • Peel off the adhesive tapes that secure the antenna cables to the system board.
      • Make note of the cable routing before removing any cable from its routing guide.
      Ask FixBot
    9. Dell Alienware 13 Display Back-Cover Replacement, Removing the Antenna Cables: step 40, image 1 of 1
      • Remove the antenna cables from the routing guides on the display hinges.
      Ask FixBot
    10. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Display Cable: step 41, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Display Cable: step 41, image 2 of 2
      • Lift the connector latch and disconnect the display cable from the system board.
      Ask FixBot
    11. Dell Alienware 13 Display Back-Cover Replacement, Removing the Display Cable: step 42, image 1 of 1
      • Remove the display cable from the routing guides on the display hinges.
      Ask FixBot
    12. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Logo-Board Cable: step 43, image 1 of 1
      • Disconnect the logo-board cable from the system board and remove it from the routing guides on the display hinges.
      Ask FixBot
    13. Dell Alienware 13 Display Back-Cover Replacement, Removing the Screws: step 44, image 1 of 1
      • Remove the screws that secure the display assembly to the computer base.
      Ask FixBot
    14. Dell Alienware 13 Display Back-Cover Replacement, Lifting the Display Assembly: step 45, image 1 of 1
      • Lift the display assembly off the computer base.
      Ask FixBot
      • Align the screw holes on the display hinges with the screw holes on the computer base.
      Ask FixBot
    15. Dell Alienware 13 Display Back-Cover Replacement, Replacing the Screws: step 47, image 1 of 1
      • Replace the screws that secure the display hinges to the computer base.
      Ask FixBot
    16. Dell Alienware 13 Display Back-Cover Replacement, Connecting the Logo-Board Cable: step 48, image 1 of 1
      • Route the logo-board cable through the routing guides on the display hinge and connect the logo-board cable to the system board.
      Ask FixBot
    17. Dell Alienware 13 Display Back-Cover Replacement, Routing the Display Cable: step 49, image 1 of 1
      • Route the display cable through the routing guides on the display hinge.
      Ask FixBot
    18. Dell Alienware 13 Display Back-Cover Replacement, Sliding the Display Cable: step 50, image 1 of 1
      • Slide the display cable into the connector on the system board and press down the latch to secure the cable.
      Ask FixBot
    19. Dell Alienware 13 Display Back-Cover Replacement, Route the Antenna Cables: step 51, image 1 of 1
      • Route the antenna cables through the routing guides on the display hinges.
      Ask FixBot
    20. Dell Alienware 13 Display Back-Cover Replacement, Adhering the Tapes: step 52, image 1 of 1
      • Adhere the adhesive tapes that secure the antenna cables to the system board.
      Ask FixBot
      Ask FixBot
    21. Dell Alienware 13 Display Back-Cover Replacement, Connecting the Antenna Cables: step 54, image 1 of 1
      • Connect the antenna cables to the wireless card.
      Ask FixBot
    22. Dell Alienware 13 Display Back-Cover Replacement, Replace the Screw: step 55, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Replace the Screw: step 55, image 2 of 2
      • Replace the screw that secures the wireless-card bracket to the wireless card.
      Ask FixBot
    23. Dell Alienware 13 Display Back-Cover Replacement, Adhering the Adhesive Tape: step 56, image 1 of 1
      • Adhere the adhesive tape to the wireless card.
      Ask FixBot
      Ask FixBot
    24. Dell Alienware 13 Display Back-Cover Replacement, Align the Screw Holes: step 58, image 1 of 1
      • Align the screw holes on the hinge caps with the screw holes on the display hinges.
      Ask FixBot
      • Replace the screws that secure the hinge caps to the display hinges.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Touchpad Cable: step 60, image 1 of 3 Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Touchpad Cable: step 60, image 2 of 3 Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Touchpad Cable: step 60, image 3 of 3
      • Lift the connector latches and disconnect the touchpad cable and the status-light cable from the power-button board.
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Peeling the Cables: step 61, image 1 of 1
      • Peel the touchpad cable and status-light cable off the keyboard bracket.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Removing the Keyboard Bracket: step 62, image 1 of 1
      • Lift the keyboard bracket off the palm-rest assembly.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Remove the Screws: step 63, image 1 of 1
      • Remove the screws that secure the keyboard to the palm-rest assembly.
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Lifting the Keyboard: step 64, image 1 of 1
      • Slide and lift the keyboard, along with the cables, off the palm-rest assembly.
      Ask FixBot
    6. Dell Alienware 13 Display Back-Cover Replacement, Aligning the Screw Holes: step 65, image 1 of 1
      • Align the screw holes on the NEW keyboard with the screw holes on the palm-rest assembly.
      Ask FixBot
    7. Dell Alienware 13 Display Back-Cover Replacement, Replacing Screws: step 66, image 1 of 1
      • Replace the screws that secure the keyboard to the palm-rest assembly.
      Ask FixBot
      • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
      Ask FixBot
    8. Dell Alienware 13 Display Back-Cover Replacement, Replace the Screws: step 68, image 1 of 1
      • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
      Ask FixBot
    9. Dell Alienware 13 Display Back-Cover Replacement, Adhering the Cables: step 69, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Adhering the Cables: step 69, image 2 of 2
      • Adhere the touchpad cable and status-light cable to the keyboard bracket.
      Ask FixBot
    10. Dell Alienware 13 Display Back-Cover Replacement, Sliding the Cables: step 70, image 1 of 1
      • Slide the touchpad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Prying the Edges: step 71, image 1 of 1
      • Using your fingertips, carefully pry up the inside edges of the display bezel.
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Lift the Display Bezel: step 72, image 1 of 1
      • Carefully lift the display bezel and turn it over.
      Ask FixBot
      • Lift the connector latches and disconnect the display-board cables from the logo board.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Disconnect the Logo-Board Cable: step 74, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Disconnect the Logo-Board Cable: step 74, image 2 of 2
      • Disconnect the logo-board cable from the logo board.
      Ask FixBot
      • Connect the logo-board cable to the logo board.
      Ask FixBot
      • Slide the display-board cables to their respective connectors on the logo board and press down the latches to secure the cables.
      Ask FixBot
      • Turn the NEW display bezel over.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Align the Display Bezel: step 78, image 1 of 1
      • Align the display bezel with the display back-cover and gently snap the display bezel into place.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Remove the Screws: step 79, image 1 of 3 Dell Alienware 13 Display Back-Cover Replacement, Remove the Screws: step 79, image 2 of 3 Dell Alienware 13 Display Back-Cover Replacement, Remove the Screws: step 79, image 3 of 3
      • Remove the screws that secure the display panel to the display back-cover.
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Lift the Display Panel: step 80, image 1 of 1
      • Gently lift the display panel and turn it over.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Lift the Connector Latch: step 81, image 1 of 3 Dell Alienware 13 Display Back-Cover Replacement, Lift the Connector Latch: step 81, image 2 of 3 Dell Alienware 13 Display Back-Cover Replacement, Lift the Connector Latch: step 81, image 3 of 3
      • Lift the connector latch and disconnect the display cable from the display panel.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Securing the Cable: step 82, image 1 of 3 Dell Alienware 13 Display Back-Cover Replacement, Securing the Cable: step 82, image 2 of 3 Dell Alienware 13 Display Back-Cover Replacement, Securing the Cable: step 82, image 3 of 3
      • Connect the display cable to the NEW display panel and press down on the connector latch to secure the cable.
      Ask FixBot
      • Turn the display panel over.
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Align the Screw Holes: step 84, image 1 of 1
      • Align the screw holes on the display panel with the screw holes on the display back-cover.
      Ask FixBot
    6. Dell Alienware 13 Display Back-Cover Replacement, Replace the Screws: step 85, image 1 of 1
      • Replace the screws that secure the display panel to the display back-cover.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Place the Display: step 86, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Camera Cable: step 87, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Disconnecting the Camera Cable: step 87, image 2 of 2
      • Disconnect the camera cable from the camera module.
      Ask FixBot
    3. Dell Alienware 13 Display Back-Cover Replacement, Pry the Camera Module: step 88, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Pry the Camera Module: step 88, image 2 of 2
      • Using a plastic scribe, pry the camera module off the display back-cover.
      Ask FixBot
    4. Dell Alienware 13 Display Back-Cover Replacement, Snapping the Module in Place: step 89, image 1 of 1
      • Using the alignment posts place the NEW camera module on the display back-cover and snap it into place.
      Ask FixBot
    5. Dell Alienware 13 Display Back-Cover Replacement, Connect the Camera Cable: step 90, image 1 of 2 Dell Alienware 13 Display Back-Cover Replacement, Connect the Camera Cable: step 90, image 2 of 2
      • Connect the camera cable to the camera module.
      Ask FixBot
    1. Dell Alienware 13 Display Back-Cover Replacement, Peeling the Display-Board Cable: step 91, image 1 of 1
      Ask FixBot
    2. Dell Alienware 13 Display Back-Cover Replacement, Display Cable Routing: step 92, image 1 of 1
      • Note the display cable routing and peel the camera cable off the display back-cover.
      Ask FixBot
      • Place the NEW display back-cover on a flat surface.
      Ask FixBot
      • Adhere the display-board cable and the camera cable to the display back-cover.
      Ask FixBot
Terrence15
80,143 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 56
All Time: 925
