Up to 20% off select tools
Dell Alienware 13 Base Panel Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
80
All Time:
1,150
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 3 - 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will show the user how to replace a cracked, broken, or damaged base panel on the Dell Alienware 13 laptop.
    1. Dell Alienware 13 Base Panel Replacement, Base Panel: step 1, image 1 of 1
      • Working on an electrical device while plugged in can cause injury due to electrical shock. Ensure that all external power is disconnected from the device.
      • Close the device and turn the device over.
      Ask FixBot
    2. Dell Alienware 13 Base Panel Replacement: step 2, image 1 of 1
      • Remove (2) 5 mm Phillips head screws attaching the small access panel to the base using a Phillips # 1 screwdriver.
      • The (2) screws are attached to the base panel with retaining clips and won't completely detach from the panel.
      Ask FixBot
    3. Dell Alienware 13 Base Panel Replacement: step 3, image 1 of 3 Dell Alienware 13 Base Panel Replacement: step 3, image 2 of 3 Dell Alienware 13 Base Panel Replacement: step 3, image 3 of 3
      Tool used on this step:
      Heavy-Duty Spudger
      Buy
      Ask FixBot
2 other people completed this guide.
Author
with
Adam Russell
898 Reputation
6 Guides authored
USF Tampa, Team 14-2, Eyestone Fall 2016 Member of USF Tampa, Team 14-2, Eyestone Fall 2016
USFT-EYESTONE-F16S14G2
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 80
All Time: 1,150
