Dell Adamo 13 Fan Replacement
    1. Dell Adamo 13 Fan Replacement, Battery: step 1, image 1 of 1
      • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
      • Flip the device over.
      Ask FixBot
    2. Dell Adamo 13 Fan Replacement: step 2, image 1 of 1
      • Remove the bottom cover by unsnapping the clips around the edge of the computer.
      • You may hear a slight pop when you pull the cover off.
      Ask FixBot
    3. Dell Adamo 13 Fan Replacement: step 3, image 1 of 1
      • Disconnect orange film wire harness from the slot it is connected to.
      • The bottom cover and battery are one piece and will be replaced as a unit.
      • Remove the battery from the device.
      Ask FixBot
    1. Dell Adamo 13 Fan Replacement, Motherboard: step 4, image 1 of 1
      • Using the Phillips #0 screwdriver, remove six 2 mm screws securing the fan and motherboard to the device.
      Ask FixBot
    2. Dell Adamo 13 Fan Replacement: step 5, image 1 of 3 Dell Adamo 13 Fan Replacement: step 5, image 2 of 3 Dell Adamo 13 Fan Replacement: step 5, image 3 of 3
      • Remove all the connections to the circuit board on top and underneath.
      • Use caution when removing connections to prevent damage.
      • Remove the motherboard from the device.
      Ask FixBot
    1. Dell Adamo 13 Fan Replacement, Fan: step 6, image 1 of 3 Dell Adamo 13 Fan Replacement, Fan: step 6, image 2 of 3 Dell Adamo 13 Fan Replacement, Fan: step 6, image 3 of 3
      • Using the Phillips #0 screwdriver, remove two 2 mm screws securing the fan to the motherboard.
      • Remove the fan from the motherboard.
      Ask FixBot
Marina Vozzella
515 Reputation
4 Guides authored
UMass Dartmouth, Team 3-7, Sinclaire Fall 2021 Member of UMass Dartmouth, Team 3-7, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S3G7
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 63
All Time: 541
