Dell AC511 Volume Knob Replacement
    1. Dell AC511 Volume Knob Replacement, Front Panel: step 1, image 1 of 3 Dell AC511 Volume Knob Replacement, Front Panel: step 1, image 2 of 3 Dell AC511 Volume Knob Replacement, Front Panel: step 1, image 3 of 3
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      Ask FixBot
    2. Dell AC511 Volume Knob Replacement: step 2, image 1 of 2 Dell AC511 Volume Knob Replacement: step 2, image 2 of 2
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. Dell AC511 Volume Knob Replacement: step 3, image 1 of 2 Dell AC511 Volume Knob Replacement: step 3, image 2 of 2
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      Ask FixBot
    1. Dell AC511 Volume Knob Replacement, Volume Knob: step 4, image 1 of 1
      • Apply a light downward pressure on the circuit board next to the volume control.
      • While doing, so carefully remove the clear piece of plastic connected to the side of the soundbar using the Halberd Spudger.
      Ask FixBot
    2. Dell AC511 Volume Knob Replacement: step 5, image 1 of 1
      • Grab the knob and rock it back and forth until you can get the Jimmy under it. Then, use the Jimmy to pull it out of the soundbar.
      • Remember to reinstall the clear piece of plastic attached to the LED when finished replacing the volume knob.
      Ask FixBot
William Cook
653 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 24
All Time: 405
