Dell AC511 Speaker Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
88
All Time:
1,110
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 3 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you suspect one or more of the speakers in your Dell AC511 soundbar has stopped working, you may need to replace them.
Tools
    1. Dell AC511 Speaker Replacement, Front Panel: step 1, image 1 of 3 Dell AC511 Speaker Replacement, Front Panel: step 1, image 2 of 3 Dell AC511 Speaker Replacement, Front Panel: step 1, image 3 of 3
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      Ask FixBot
    2. Dell AC511 Speaker Replacement: step 2, image 1 of 2 Dell AC511 Speaker Replacement: step 2, image 2 of 2
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. Dell AC511 Speaker Replacement: step 3, image 1 of 2 Dell AC511 Speaker Replacement: step 3, image 2 of 2
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      Ask FixBot
    1. Dell AC511 Speaker Replacement, Speaker: step 4, image 1 of 2 Dell AC511 Speaker Replacement, Speaker: step 4, image 2 of 2
      • Follow the three wires connected to the speaker to find where they connect to the circuit board.
      • Use tweezers to gently rock the end of the wires back and forth until they disconnect from the board.
      Ask FixBot
William Cook
653 Reputation
6 Guides authored
1 Guide Comment
where can I get the compatible speaker head?
Chanthachon Senesouphap - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 88
All Time: 1,110
