Up to 20% off select tools
Dell AC511 Front Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
5
Past 7 Days:
24
Past 30 Days:
112
All Time:
1,819
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Taking off the front panel is a requirement for replacing any part inside or around the speaker, and if improperly done may lead to damage to the speaker or self.
    1. Dell AC511 Front Panel Replacement, Front Panel: step 1, image 1 of 3 Dell AC511 Front Panel Replacement, Front Panel: step 1, image 2 of 3 Dell AC511 Front Panel Replacement, Front Panel: step 1, image 3 of 3
      • Use a Jimmy to peel off the screen stuck to the front of the speaker.
      • Start from any corner and use the Jimmy to get under the screen. Once one side lifts up, you can use your fingers to peel the rest off.
      • Be careful to avoid damage to the rest of the speaker and especially to yourself.
      • Don't worry if it tears; use the Jimmy again to peel off the rest.
      Ask FixBot
    2. Dell AC511 Front Panel Replacement: step 2, image 1 of 2 Dell AC511 Front Panel Replacement: step 2, image 2 of 2
      • Remove ten 6 mm screws using a Phillips #1 screwdriver.
      Ask FixBot
    3. Dell AC511 Front Panel Replacement: step 3, image 1 of 2 Dell AC511 Front Panel Replacement: step 3, image 2 of 2
      • Lift the front panel off of the rest of the device.
      • The speakers will still be attached to the front panel. Being too rough could damage them.
      • Remove the 4 mm screws from the speakers using a JIS #1 screwdriver.
      • Remove the front panel from the device.
      Ask FixBot
Author
with
William Cook
653 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 24
Past 30 Days: 112
All Time: 1,819
