Dell 1350cnw Side Cover Replacement
  1. Dell 1350cnw Side Cover Replacement, Unclip front top band: step 1, image 1 of 2 Dell 1350cnw Side Cover Replacement, Unclip front top band: step 1, image 2 of 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
    Ask FixBot
  2. Dell 1350cnw Side Cover Replacement, Unclip front top band: step 2, image 1 of 2 Dell 1350cnw Side Cover Replacement, Unclip front top band: step 2, image 2 of 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
    Ask FixBot
  3. Dell 1350cnw Side Cover Replacement, Remove front top band: step 3, image 1 of 1
    • Tilt the top of the front band away from the printer and lift away to remove.
    Ask FixBot
  4. Dell 1350cnw Side Cover Replacement, Remove left-side top band: step 4, image 1 of 3 Dell 1350cnw Side Cover Replacement, Remove left-side top band: step 4, image 2 of 3 Dell 1350cnw Side Cover Replacement, Remove left-side top band: step 4, image 3 of 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
    Ask FixBot
  5. Dell 1350cnw Side Cover Replacement, Remove control panel module: step 5, image 1 of 3 Dell 1350cnw Side Cover Replacement, Remove control panel module: step 5, image 2 of 3 Dell 1350cnw Side Cover Replacement, Remove control panel module: step 5, image 3 of 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
    Ask FixBot
  6. Dell 1350cnw Side Cover Replacement, Remove front cover: step 6, image 1 of 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
    Ask FixBot
  7. Dell 1350cnw Side Cover Replacement, Remove front cover: step 7, image 1 of 1
    • Remove both 7mm phillips screws securing the front cover in place.
    Ask FixBot
  8. Dell 1350cnw Side Cover Replacement, Remove front cover: step 8, image 1 of 3 Dell 1350cnw Side Cover Replacement, Remove front cover: step 8, image 2 of 3 Dell 1350cnw Side Cover Replacement, Remove front cover: step 8, image 3 of 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
    Ask FixBot
  9. Dell 1350cnw Side Cover Replacement, Remove front cover: step 9, image 1 of 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
    Ask FixBot
  10. Dell 1350cnw Side Cover Replacement, Remove top cover: step 10, image 1 of 2 Dell 1350cnw Side Cover Replacement, Remove top cover: step 10, image 2 of 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
    Ask FixBot
  11. Dell 1350cnw Side Cover Replacement, Remove top cover: step 11, image 1 of 2 Dell 1350cnw Side Cover Replacement, Remove top cover: step 11, image 2 of 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
    Ask FixBot
  12. Dell 1350cnw Side Cover Replacement, Remove top cover: step 12, image 1 of 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
    Ask FixBot
  13. Dell 1350cnw Side Cover Replacement, Remove top cover: step 13, image 1 of 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
    Ask FixBot
  14. Dell 1350cnw Side Cover Replacement, Remove top cover: step 14, image 1 of 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
    Ask FixBot
  15. Dell 1350cnw Side Cover Replacement, Remove side cover: step 15, image 1 of 3 Dell 1350cnw Side Cover Replacement, Remove side cover: step 15, image 2 of 3 Dell 1350cnw Side Cover Replacement, Remove side cover: step 15, image 3 of 3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
    Ask FixBot
Jac
2,728 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 188
