Dell 1350cnw Main Drive Motor Replacement
  1. Dell 1350cnw Main Drive Motor Replacement, Unclip front top band: step 1, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Unclip front top band: step 1, image 2 of 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
    Ask FixBot
  2. Dell 1350cnw Main Drive Motor Replacement, Unclip front top band: step 2, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Unclip front top band: step 2, image 2 of 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
    Ask FixBot
  3. Dell 1350cnw Main Drive Motor Replacement, Remove front top band: step 3, image 1 of 1
    • Tilt the top of the front band away from the printer and lift away to remove.
    Ask FixBot
  4. Dell 1350cnw Main Drive Motor Replacement, Remove left-side top band: step 4, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove left-side top band: step 4, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove left-side top band: step 4, image 3 of 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
    Ask FixBot
  5. Dell 1350cnw Main Drive Motor Replacement, Remove control panel module: step 5, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove control panel module: step 5, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove control panel module: step 5, image 3 of 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
    Ask FixBot
  6. Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 6, image 1 of 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
    Ask FixBot
  7. Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 7, image 1 of 1
    • Remove both 7mm phillips screws securing the front cover in place.
    Ask FixBot
  8. Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 8, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 8, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 8, image 3 of 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
    Ask FixBot
  9. Dell 1350cnw Main Drive Motor Replacement, Remove front cover: step 9, image 1 of 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
    Ask FixBot
  10. Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 10, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 10, image 2 of 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
    Ask FixBot
  11. Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 11, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 11, image 2 of 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
    Ask FixBot
  12. Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 12, image 1 of 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
    Ask FixBot
  13. Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 13, image 1 of 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
    Ask FixBot
  14. Dell 1350cnw Main Drive Motor Replacement, Remove top cover: step 14, image 1 of 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
    Ask FixBot
  15. Dell 1350cnw Main Drive Motor Replacement, Remove side cover: step 15, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove side cover: step 15, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove side cover: step 15, image 3 of 3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
    Ask FixBot
  16. Dell 1350cnw Main Drive Motor Replacement, Unplug WiFi module: step 16, image 1 of 1
    • Pull out the WiFi module plug from the USB/Ethernet board to disconnect.
    Ask FixBot
  17. Dell 1350cnw Main Drive Motor Replacement, Remove WiFi module: step 17, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Remove WiFi module: step 17, image 2 of 2
    • Unscrew the 7mm phillips screw holding the WiFi module to the printer and remove the WiFi module.
    Ask FixBot
  18. Dell 1350cnw Main Drive Motor Replacement, Unplug cables: step 18, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Unplug cables: step 18, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Unplug cables: step 18, image 3 of 3
    • Lift up the locking tab to unclip and release the flat flex data cable.
    • Gently pull the flat flex cable out from from the connector.
    Ask FixBot
  19. Dell 1350cnw Main Drive Motor Replacement, Unplug cables: step 19, image 1 of 1
    • Pull the smaller flat flex cable out from its connector to remove, and repeat for the remaining two connectors.
    Ask FixBot
  20. Dell 1350cnw Main Drive Motor Replacement, Remove USB/Ethernet board: step 20, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove USB/Ethernet board: step 20, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove USB/Ethernet board: step 20, image 3 of 3
    • Unscrew the 4mm M3 phillips screw holding the USB connector to the rear cover plate.
    • Unscrew the four 5mm M3 phillips screws holding the USB/Ethernet board to the bracket and remove the board from the printer.
    Ask FixBot
  21. Dell 1350cnw Main Drive Motor Replacement, Unscrew fan bracket: step 21, image 1 of 1
    • Unscrew the 5mm M3 phillips screw from the fan bracket.
    • Unhook the retaining clip on the lower right-hand side of the fan bracket to loosen from the printer.
    Ask FixBot
  22. Dell 1350cnw Main Drive Motor Replacement, Remove fan bracket: step 22, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove fan bracket: step 22, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove fan bracket: step 22, image 3 of 3
    • De-route the cables from the USB/Ethernet board and remove from the harness on the back of the fan shroud.
    • Pull out the four circled cable connectors to unplug, and de-route the remaining cables from the wiring harness.
    • Lift away the fan/bracket assembly from the printer to remove.
    Ask FixBot
  23. Dell 1350cnw Main Drive Motor Replacement, De-route cables: step 23, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, De-route cables: step 23, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, De-route cables: step 23, image 3 of 3
    • Pull out all the indicated cable plugs from the main control board.
    • De-route all the cables from the wiring harness on the side of the printer.
    Ask FixBot
  24. Dell 1350cnw Main Drive Motor Replacement, Remove side cable bracket: step 24, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove side cable bracket: step 24, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove side cable bracket: step 24, image 3 of 3
    • Push in the retaining pin on the lower right-hand corner of the lower cable bracket, pulling the bracket out slightly away from the printer.
    • Push down the retaining pin on the top left of the cable bracket, and pull down and out from under the USB/Ethernet board support bracket.
    • Pull the cable bracket away from the printer.
    Ask FixBot
  25. Dell 1350cnw Main Drive Motor Replacement, Remove cover plate: step 25, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Remove cover plate: step 25, image 2 of 2
    • Pull out the flat flex cable to remove from the top of the image output board.
    • Unscrew the four 5mm M3 phillips screws at the corners of the image output board over plate.
    Ask FixBot
  26. Dell 1350cnw Main Drive Motor Replacement, Remove flat flex cables: step 26, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove flat flex cables: step 26, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove flat flex cables: step 26, image 3 of 3
    • Flip up the retaining bar on each of the five flat flex cable connectors and gently lift out the cable to remove.
    Ask FixBot
  27. Dell 1350cnw Main Drive Motor Replacement, Remove USB/Ethernet board bracket: step 27, image 1 of 2 Dell 1350cnw Main Drive Motor Replacement, Remove USB/Ethernet board bracket: step 27, image 2 of 2
    • Unscrew the three 5mm M3 phillips screws holding the USB/Ethernet board bracket to the printer, and remove the bracket.
    Ask FixBot
  28. Dell 1350cnw Main Drive Motor Replacement, Remove small gear carrier: step 28, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove small gear carrier: step 28, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove small gear carrier: step 28, image 3 of 3
    • Pull off the 30mm gear cog.
    • Unscrew both the 5mm M3 phillips screws holding the small gear carrier assembly in place.
    • Tilt the gear carrier away from the printer and remove.
    • Tilting the top edge away first as shown helps stop the gears falling off when removing this part.
    Ask FixBot
  29. Dell 1350cnw Main Drive Motor Replacement, Remove motor assembly: step 29, image 1 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove motor assembly: step 29, image 2 of 3 Dell 1350cnw Main Drive Motor Replacement, Remove motor assembly: step 29, image 3 of 3
    • Unscrew the two 5mm M4 phillips screws.
    • Unscrew the 7mm phillips screw.
    • Pull off the 25mm gear. (This usually allows the adjacent gear (green arrow, behind the outer bracket) to come off with the motor/ drive assembly; if it doesn't, this gear can be put back on afterwards).
    • Pull away the main drive motor/gear assembly from the printer to remove.
    • The 25mm drive gear (yellow arrow) and 30mm gear (orange arrow) can be replaced once the motor assembly is removed.
    Ask FixBot
Jac
2,728 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 24
All Time: 165
