Dell 1350cnw HV Board Replacement
  1. Dell 1350cnw HV Board Replacement, Unclip front top band: step 1, image 1 of 2 Dell 1350cnw HV Board Replacement, Unclip front top band: step 1, image 2 of 2
    • Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
    • Note - Unclipping the right-hand end requires opening the toner cover for access.
    Ask FixBot
  2. Dell 1350cnw HV Board Replacement, Unclip front top band: step 2, image 1 of 2 Dell 1350cnw HV Board Replacement, Unclip front top band: step 2, image 2 of 2
    • Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
    Ask FixBot
  3. Dell 1350cnw HV Board Replacement, Remove front top band: step 3, image 1 of 1
    • Tilt the top of the front band away from the printer and lift away to remove.
    Ask FixBot
  4. Dell 1350cnw HV Board Replacement, Remove left-side top band: step 4, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove left-side top band: step 4, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove left-side top band: step 4, image 3 of 3
    • Unclip the back end of the plastic trim by prying away from the printer back panel.
    • Pull the trim piece towards the back of the printer.
    • Tilt the top edge away from the printer and lift away to remove.
    Ask FixBot
  5. Dell 1350cnw HV Board Replacement, Remove control panel module: step 5, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove control panel module: step 5, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove control panel module: step 5, image 3 of 3
    • Pry up front edge of the control panel module to unclip.
    • Lift up front edge and pull module forwards slightly to unhook rear edge.
    • Pull out cable connector to unplug the display/ control panel module.
    Ask FixBot
  6. Dell 1350cnw HV Board Replacement, Remove front cover: step 6, image 1 of 1
    • Remove the front lower flap by carefully bending in the middle and pulling out the locating pins one end at a time.
    Ask FixBot
  7. Dell 1350cnw HV Board Replacement, Remove front cover: step 7, image 1 of 1
    • Remove both 7mm phillips screws securing the front cover in place.
    Ask FixBot
  8. Dell 1350cnw HV Board Replacement, Remove front cover: step 8, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove front cover: step 8, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove front cover: step 8, image 3 of 3
    • Unclip the three clips along each end of the front cover by prying outwards and forwards with a prying tool as shown.
    Ask FixBot
  9. Dell 1350cnw HV Board Replacement, Remove front cover: step 9, image 1 of 1
    • Slide out the bottom edge away from the printer and pull the front cover down away from the top edge to remove.
    Ask FixBot
  10. Dell 1350cnw HV Board Replacement, Remove top cover: step 10, image 1 of 2 Dell 1350cnw HV Board Replacement, Remove top cover: step 10, image 2 of 2
    • Undo both the 5mm M3 phillips screws holding the top cover brackets to the chassis.
    Ask FixBot
  11. Dell 1350cnw HV Board Replacement, Remove top cover: step 11, image 1 of 2 Dell 1350cnw HV Board Replacement, Remove top cover: step 11, image 2 of 2
    • Pull the top cover brackets forwards off the metal frame and lift up to loosen the front edge of the top cover.
    Ask FixBot
  12. Dell 1350cnw HV Board Replacement, Remove top cover: step 12, image 1 of 1
    • Pry the top cover clip off the locating peg at the back of the printer, and lift up the top cover corner.
    Ask FixBot
  13. Dell 1350cnw HV Board Replacement, Remove top cover: step 13, image 1 of 1
    • Pry apart the back edge of the top cover and the back cover of the printer to unclip the top cover.
    Ask FixBot
  14. Dell 1350cnw HV Board Replacement, Remove top cover: step 14, image 1 of 1
    • Lift up the top cover from the control panel corner, pulling towards the back right-hand corner.
    • Note - The top cover should unclip from the back corner with the corner/side piece still attached.
    Ask FixBot
  15. Dell 1350cnw HV Board Replacement, Remove side cover: step 15, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove side cover: step 15, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove side cover: step 15, image 3 of 3
    • Unclip the back edge of the side cover by prying away from the printer back panel.
    • Pull the top of the side panel away from the printer.
    • Lift up the printer from underneath to release the bottom clips, and the side panel drops away from the printer.
    Ask FixBot
  16. Dell 1350cnw HV Board Replacement, Remove back cover: step 16, image 1 of 1
    • Remove the four 7mm phillips screws holding the rear cover to the printer.
    Ask FixBot
  17. Dell 1350cnw HV Board Replacement, Unplug sensor cable: step 17, image 1 of 2 Dell 1350cnw HV Board Replacement, Unplug sensor cable: step 17, image 2 of 2
    • Pull out the connector for the rear cover sensor from the power supply board.
    • De-route the light pink coloured pair of sensor cables and remove from the wiring harness.
    Ask FixBot
  18. Dell 1350cnw HV Board Replacement, Remove back cover: step 18, image 1 of 1
    • Unclip the rear cover opposite the de-routed cables by prying away from the rest of the printer using a prying tool.
    • The rear cover can now be removed from the printer.
    Ask FixBot
  19. Dell 1350cnw HV Board Replacement, Remove fuser unit: step 19, image 1 of 2 Dell 1350cnw HV Board Replacement, Remove fuser unit: step 19, image 2 of 2
    • Unscrew the 9mm phillips screw.
    • Unscrew the 9mm Torx TR10 security screw.
    Ask FixBot
  20. Dell 1350cnw HV Board Replacement, Remove fuser unit: step 20, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove fuser unit: step 20, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove fuser unit: step 20, image 3 of 3
    • Unplug the fuser power cable by squeezing the top of the retaining clip and pulling the connector up from the power supply board.
    • De-route the fuser power cable and remove from the cable restraint.
    • Pull up on the two fuser unit control cable connectors to unplug from the control board.
    • De-route the two sets of control cables from the control board to the fuser unit and remove from the wiring harness.
    Ask FixBot
  21. Dell 1350cnw HV Board Replacement, Remove fuser unit: step 21, image 1 of 2 Dell 1350cnw HV Board Replacement, Remove fuser unit: step 21, image 2 of 2
    • Lift up fuser unit to remove from the printer.
    Ask FixBot
  22. Dell 1350cnw HV Board Replacement, Unscrew HV board: step 22, image 1 of 1
    • Unscrew the five 7mm phillips screws around the edges of the HV board.
    Ask FixBot
  23. Dell 1350cnw HV Board Replacement, Loosen fan shroud: step 23, image 1 of 1
    • Unscrew and unclip the fan shroud support bracket to the lower-right of the fan.
    Ask FixBot
  24. Dell 1350cnw HV Board Replacement, Remove HV board: step 24, image 1 of 2 Dell 1350cnw HV Board Replacement, Remove HV board: step 24, image 2 of 2
    • Pull the fan shroud away from the HV board and lift the PCB up and off the locating peg.
    • Once clear of the locating peg, pull the PCB towards the front of the printer to slide out from beneath the back part of the fan shroud/ cable support.
    Ask FixBot
  25. Dell 1350cnw HV Board Replacement, Remove HV board: step 25, image 1 of 3 Dell 1350cnw HV Board Replacement, Remove HV board: step 25, image 2 of 3 Dell 1350cnw HV Board Replacement, Remove HV board: step 25, image 3 of 3
    • Pull up the HV board cable connector to disconnect from the control board.
    • Lift up the HV board from the end nearest the fan to lift over the locating peg at the other end and remove from the printer.
    Ask FixBot
Jac
2,728 Reputation
21 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 9
Past 30 Days: 27
All Time: 117
