Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓Replacement guide for the control panel/ screen module for the Dell 1350cnw printer
Insert prying tool behind each end of the plastic strip. Pry outwards to unclip and pull the ends forwards away from the printer.
Note - Unclipping the right-hand end requires opening the toner cover for access.
Insert prying tool between the front band and top cover of the printer, and pry forwards to release the clips holding the top edge in place.
Tilt the top of the front band away from the printer and lift away to remove.
Unclip the back end of the plastic trim by prying away from the printer back panel.
Pull the trim piece towards the back of the printer.
Tilt the top edge away from the printer and lift away to remove.
Pry up front edge of the control panel module to unclip.
Lift up front edge and pull module forwards slightly to unhook rear edge.
Pull out cable connector to unplug the display/ control panel module.
