Definitive Technology W7 Motherboard Replacement
    1. Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Definitive Technology W7 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Flip the speaker upside down, then use the Phillips #2 screwdriver remove the 4 screws securing the bottom cover.
      • The screw next to the I/O panel will be approximately 20 mm in length. The other screws will be approximately 35 mm in length.
      • Use the metal spudger to remove all rubber feet.
      • Unscrew all four screws from under the rubber feet.
      • These screws will be approximately 35 mm in length.
      • You can now use the prying tool to pry the bottom panel off the speaker.
      Ask FixBot
    2. Definitive Technology W7 Motherboard Replacement: step 2, image 1 of 1
      • Using a Phillips #2 screwdriver, remove the 5 screws from the motherboard.
      • These screws are approximately 8 mm in length.
      Ask FixBot
    3. Definitive Technology W7 Motherboard Replacement: step 3, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 3, image 2 of 2
      • Push up the locking tabs on the sides of the ribbon cable connector.
      • Gently pull the ribbon cable out from the connector to remove it.
      Ask FixBot
    4. Definitive Technology W7 Motherboard Replacement: step 4, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 4, image 2 of 2
      • Tilt the motherboard outwards from the speaker.
      • Remove all five connectors from the motherboard.
      • Remove the motherboard from the speaker.
      Ask FixBot
    5. Definitive Technology W7 Motherboard Replacement: step 5, image 1 of 2 Definitive Technology W7 Motherboard Replacement: step 5, image 2 of 2
      • Using the Phillips #2 screwdriver, remove the three screws from the network card.
      • These screws are approximately 8mm in length.
      • Remove the network card from the motherboard.
      Ask FixBot
Magnus Maillet
171 Reputation
1 Guide authored
UMass Dartmouth, Team 2-5, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-5, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 772
