Up to 20% off select tools
Decorative Light Fixture Lightbulb Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
7
Past 7 Days:
31
Past 30 Days:
127
All Time:
1,457
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Many homes have decorative light fixtures, and for good reason. They look much more interesting than your average lightbulb. However, they also make it harder to change your lightbulbs. That is why knowing how to safely take them apart is a great skill to learn, which is exactly what this guide is here to help you do. Be sure your replacement bulb is compatible with your light fixture.
Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
    1. Decorative Light Fixture Lightbulb Replacement, Lightbulb: step 1, image 1 of 1
      • WARNING: Before beginning this guide, turn off the power from the circuit breaker, and turn off any light switches that provide power to the item you’re working on.
      • Position a sturdy ladder beneath the light fixture.
      Ask FixBot
    2. Decorative Light Fixture Lightbulb Replacement: step 2, image 1 of 2 Decorative Light Fixture Lightbulb Replacement: step 2, image 2 of 2
      • Hold onto the fixture with one hand, and use the screwdriver to start unscrewing the fixture with your other hand.
      • If possible, have someone else hold the fixture for you.
      • Caution: Be careful not to drop the fixture. Broken glass can be very dangerous.
      Ask FixBot
    3. Decorative Light Fixture Lightbulb Replacement: step 3, image 1 of 1
      • Place the fixture and any loose screws off to the side.
      Ask FixBot
    4. Decorative Light Fixture Lightbulb Replacement: step 4, image 1 of 2 Decorative Light Fixture Lightbulb Replacement: step 4, image 2 of 2
      • Unscrew the lightbulb from the fixture.
      Ask FixBot
    5. Decorative Light Fixture Lightbulb Replacement: step 5, image 1 of 1
      • Check to make sure that your replacement lightbulb matches the necessary type for the fixture.
      Ask FixBot
    6. Decorative Light Fixture Lightbulb Replacement: step 6, image 1 of 2 Decorative Light Fixture Lightbulb Replacement: step 6, image 2 of 2
      • Re-screw the lightbulb into the fixture.
      Ask FixBot
    7. Decorative Light Fixture Lightbulb Replacement: step 7, image 1 of 2 Decorative Light Fixture Lightbulb Replacement: step 7, image 2 of 2
      • Hold onto the fixture, and screw it back in with the screwdriver.
      Ask FixBot
Finish Line
Author
with
Jordan Parry
172 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 31
Past 30 Days: 127
All Time: 1,457
