DeckLink HD Extreme 3D+ Fan Replacement
    1. DeckLink HD Extreme 3D+ Fan Replacement, Before and after: step 1, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement, Before and after: step 1, image 2 of 2
      • Original fan.
      • Replaced fan. 40mm square.
      Ask FixBot
    2. DeckLink HD Extreme 3D+ Fan Replacement, Connector: step 2, image 1 of 1
      • Remember the cable colors at the connector and which position they are!
      • WARNING: Be carefull here. I did choose to trial and error to find the solution. But you might break your PC or the board.
      Ask FixBot
    3. DeckLink HD Extreme 3D+ Fan Replacement, Take off the fan: step 3, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement, Take off the fan: step 3, image 2 of 2
      • Take out these 4 screws.
      • Disconnect the micro JST.
      Ask FixBot
    4. DeckLink HD Extreme 3D+ Fan Replacement, Replacement parts: step 4, image 1 of 1
      • Get all your replacement parts around.
      Ask FixBot
    5. DeckLink HD Extreme 3D+ Fan Replacement: step 5, image 1 of 2 DeckLink HD Extreme 3D+ Fan Replacement: step 5, image 2 of 2
      • My replacement JST came in a different color order.
      • I assumed the fan I bought would have the same colored connection as the original one. Result: positive.
      • So I did switch the black with the red color. But be sure to check which cable colors your JSTs come with and which order they have.
      • Check step 2: Remember the connection order. You might break something.
      • The connectors have to match with the board. Otherwise the fan is spinning the wrong direction.
      Ask FixBot
    6. DeckLink HD Extreme 3D+ Fan Replacement, Isolate the connection: step 6, image 1 of 1
      • Be sure to isolate the connection.
      Ask FixBot
    7. DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 1 of 3 DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 2 of 3 DeckLink HD Extreme 3D+ Fan Replacement, Bring on the fan: step 7, image 3 of 3
      • Tighten the fan carefully.
      • Make sure it sits well and is tight! Otherwise you get movement noise.
      • I know, mine isn't perfectly aligned. But it does work for me.
      Ask FixBot
3 other people completed this guide.
Wolfgang
779 Reputation
3 Guides authored
2 Guide Comments
i wonder how you'd put another card one next to this with new fan contraption protruding beyond limits :|
also, heatsink mounting hole distance is not stated so the whole guide is pretty much useless, except for original fan model being disclosed ;p
p····· g······· - Reply Share
@ujczmbg9clcci9r true, the spot next to the card will be not available for other cards. unless you find a different replacement fan...
and for the distance: its not that tight/important, the screws go in the heatsink below which allows a little leeway.
Wolfgang - Reply Share
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 44
All Time: 1,981
