Up to 20% off select tools
DeWalt_D26451 Brake Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
124
All Time:
3,269
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The DeWalt D26451's brake function may go bad after heavy usage.
In this guide, we will be teaching you how to replace the brake on the D26451. You can purchase a replacement brake here.
    1. DeWalt_D26451 Brake Replacement, Pad: step 1, image 1 of 3 DeWalt_D26451 Brake Replacement, Pad: step 1, image 2 of 3 DeWalt_D26451 Brake Replacement, Pad: step 1, image 3 of 3
      • Please wear safety glasses while completing this replacement guide.
      • Insert the 60 mm extension into the screw driver which has the t15 torx bit installed in order to make a t-handle grip.
      • Turn the screwdriver counter-clockwise to loosen all three screws in the disc pad.
      Ask FixBot
    2. DeWalt_D26451 Brake Replacement: step 2, image 1 of 2 DeWalt_D26451 Brake Replacement: step 2, image 2 of 2
      • Turn the disc pad over and remove the loosened screws.
      • When the screws are removed, the disc pad will come off of the sander.
      Ask FixBot
    1. DeWalt_D26451 Brake Replacement, Brake: step 3, image 1 of 1
      • Please wear safety glasses while completing this repair guide.
      • Loosen and remove the three screws on the bottom of the sander that holds the disc pad to the bottom of the sander.
      Ask FixBot
    2. DeWalt_D26451 Brake Replacement: step 4, image 1 of 1
      • After the T20 torx bolts have been removed, remove the disc pad from the sander.
      Ask FixBot
    3. DeWalt_D26451 Brake Replacement: step 5, image 1 of 1
      • When the disc pad is removed, the brake is located directly under it. Remove the brake from the sander.
      Ask FixBot
Author
with
Shelby LeQuire
639 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 124
All Time: 3,269
