DeWalt Jobsite DCR010 Power Inlet Replacement
    1. DeWalt Jobsite DCR010 Power Inlet Replacement, Case: step 1, image 1 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement, Case: step 1, image 2 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement, Case: step 1, image 3 of 3
      • Remove the eleven 15 mm screws on the corners and back of the device casing using a Phillips #2 screwdriver.
      • If you're using the iFixit tool kit, you may need to utilize the 4 mm nut driver as an extension in order to reach the deep screws on the backside of the case.
      Ask FixBot
    2. DeWalt Jobsite DCR010 Power Inlet Replacement: step 2, image 1 of 1
      • Take the casing apart by pulling the rubber corners away from the body of the speaker.
      • Pull the top handle away from the body of the case once the corners are removed.
      Ask FixBot
    3. DeWalt Jobsite DCR010 Power Inlet Replacement: step 3, image 1 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement: step 3, image 2 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement: step 3, image 3 of 3
      • Remove or slice the DeWalt sticker on the left side of the device in.
      • Push out the two pins on the top of the device.
      • You may need to pry at the bottom of the device, if so, use an opening tool.
      Ask FixBot
    4. DeWalt Jobsite DCR010 Power Inlet Replacement: step 4, image 1 of 2 DeWalt Jobsite DCR010 Power Inlet Replacement: step 4, image 2 of 2
      • Unplug the connections running between the two sides of the case by pinching the tab on the non-speaker side and pulling away from the point of attachment.
      Ask FixBot
    1. DeWalt Jobsite DCR010 Power Inlet Replacement, Motherboard: step 5, image 1 of 2 DeWalt Jobsite DCR010 Power Inlet Replacement, Motherboard: step 5, image 2 of 2
      • Remove the wired connections to the motherboard by squeezing the plastic tab and pulling away from the point of connection.
      Ask FixBot
    2. DeWalt Jobsite DCR010 Power Inlet Replacement: step 6, image 1 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement: step 6, image 2 of 3 DeWalt Jobsite DCR010 Power Inlet Replacement: step 6, image 3 of 3
      • Unscrew the four 10 mm screws securing the motherboard with a Phillips #2 screwdriver.
      • Lift the motherboard up and out of the device.
      Ask FixBot
    1. DeWalt Jobsite DCR010 Power Inlet Replacement, Power Inlet: step 7, image 1 of 2 DeWalt Jobsite DCR010 Power Inlet Replacement, Power Inlet: step 7, image 2 of 2
      • Remove the four 15 mm screws holding the cover in place using a Phillips #2 screwdriver.
      • Remove the cover and set it asside.
      Ask FixBot
    2. DeWalt Jobsite DCR010 Power Inlet Replacement: step 8, image 1 of 1
      • Unscrew the two 15 mm screws holding the C8 Power inlet in place using the Phillips #2 screwdriver.
      • Pull the power inlet out of its slot.
      Ask FixBot
    3. DeWalt Jobsite DCR010 Power Inlet Replacement: step 9, image 1 of 1
      • Take note of where the silicone adhesive is applied, you will need to reapply it after replacing the inlet.
      • Using an opening tool or small pliers, remove the silicone adhesive surrounding the wires.
      • Ensure that the board is clean and free of residue before moving on to the next step.
      Ask FixBot
    4. DeWalt Jobsite DCR010 Power Inlet Replacement: step 10, image 1 of 1
      • Remember which wire attached to either side of the original power inlet.
      • Use the solder pump or desoldering wick to desolder the wires and C8 inlet from the board.
      • Click here for a guide on how to solder and unsolder.
      • Solder in the new replacement inlet with the wires to the motherboard.
      • Make sure the correct wires are soldered to the appropriate points.
      • Replace the silicone adhesive that previously surrounded the wires.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Fabrizio Fonseca
159 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 59
All Time: 169
