Introduction
Go to step 1 ↓This replacement guide includes instructions on how to replace the LED light located at the front of the DCR010, just under the control panel.
This process requires you to solder and desolder, so before we begin the replacement process, it is important to prioritize your safety. Soldering and desoldering involve high temperatures, causing potential health risks to you or those around you during this process. Make sure you are following this guide while in a ventilated area.
If you are new to soldering and desoldering electronic connections, please follow iFixit's Soldering Guide before beginning the LED replacement.
Tools
Remove the eleven 15 mm screws on the corners and back of the device casing using a Phillips #2 screwdriver.
Inside the front panel, remove the three 15 mm screws holding the control panel to the inside of the device using the Phillips #2 screwdriver.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
