DeWalt DWE4011 Power Switch Replacement
    1. DeWalt DWE4011 Power Switch Replacement, Power Switch: step 1, image 1 of 1
      • Turn to the bottom of the device and remove the 1 1/4" screw shown using a T15 Torx Screwdriver.
      Ask FixBot
    2. DeWalt DWE4011 Power Switch Replacement: step 2, image 1 of 1
      • Remove the outer casing by pulling the end handle away from the field case.
      Ask FixBot
    3. DeWalt DWE4011 Power Switch Replacement: step 3, image 1 of 1
      • Unscrew the pin that is holding the main power cord in place and remove the cord.
      Ask FixBot
    4. DeWalt DWE4011 Power Switch Replacement: step 4, image 1 of 2 DeWalt DWE4011 Power Switch Replacement: step 4, image 2 of 2
      • Pull back the tab holding the switch box in place using a nylon spudger. There is one on top and bottom shown in the image.
      Ask FixBot
    5. DeWalt DWE4011 Power Switch Replacement: step 5, image 1 of 1
      • Remove the switch box entirely from its normal position. Gently pull off the connections from the switch box to the motor.
      Ask FixBot
    6. DeWalt DWE4011 Power Switch Replacement: step 6, image 1 of 2 DeWalt DWE4011 Power Switch Replacement: step 6, image 2 of 2
      • Using a small Phillips head screwdriver, remove the screws that hold the white colored wires from the power cord in place.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 49
All Time: 2,171
