DeWalt DWE4011 Power Cable Replacement
    1. DeWalt DWE4011 Power Cable Replacement, Power Cord: step 1, image 1 of 1
      • Turn to the bottom of the device and remove the 5/8" (17mm) T15 Torx screw.
      Ask FixBot
    2. DeWalt DWE4011 Power Cable Replacement: step 2, image 1 of 2 DeWalt DWE4011 Power Cable Replacement: step 2, image 2 of 2
      • Remove bottom casing by separating the end handle away from the main casing.
      Ask FixBot
    3. DeWalt DWE4011 Power Cable Replacement: step 3, image 1 of 2 DeWalt DWE4011 Power Cable Replacement: step 3, image 2 of 2
      • Remove the 1/2” (13mm) Phillips #2 screw holding the power cable to the device. This will free up the metal clamp holding the cable in place.
      Ask FixBot
    4. DeWalt DWE4011 Power Cable Replacement: step 4, image 1 of 1
      • Flip the grinder over and disconnect the plastic switch mechanism from the cable housing.
      Ask FixBot
    5. DeWalt DWE4011 Power Cable Replacement: step 5, image 1 of 2 DeWalt DWE4011 Power Cable Replacement: step 5, image 2 of 2
      • Pull back the yellow tab holding the housing in place using a nylon spudger. Carefully pull the housing out of the casing.
      Ask FixBot
    6. DeWalt DWE4011 Power Cable Replacement: step 6, image 1 of 2 DeWalt DWE4011 Power Cable Replacement: step 6, image 2 of 2
      • Locate the terminals with the two white cables attached and disconnect both.
      • These cables are connected to the outer terminals; connect as such during reassembly.
      Ask FixBot
    7. DeWalt DWE4011 Power Cable Replacement: step 7, image 1 of 2 DeWalt DWE4011 Power Cable Replacement: step 7, image 2 of 2
      • Remove the entirety of the cable housing from the device casing.
      • The two wires coming from the power cable should still be connected to electrical housing at this point.
      Ask FixBot
    8. DeWalt DWE4011 Power Cable Replacement: step 8, image 1 of 1
      • Loosen the Phillips #2 screws enough to disconnect the two wires from the power cable housing.
      • Removing the screw entirely is fine, but unnecessary since the screws are merely clamping down the wires' ends.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
Where can I find a replacement power cord?
Ethan Sligar - Reply Share
Past 24 Hours: 8
Past 7 Days: 25
Past 30 Days: 100
All Time: 4,896
