DeWalt DWE4011 Brush Spring Replacement
    1. DeWalt DWE4011 Brush Spring Replacement, Brush Spring: step 1, image 1 of 1
      • Turn to the bottom of the device and remove the 5/8" (17mm) screw shown using a T15 Torx Screwdriver.
      Ask FixBot
    2. DeWalt DWE4011 Brush Spring Replacement: step 2, image 1 of 1
      • Remove outer casing by pulling the end handle away from the field case.
      Ask FixBot
    3. DeWalt DWE4011 Brush Spring Replacement: step 3, image 1 of 1
      • Locate the brush springs on either side of the device.
      Ask FixBot
    4. DeWalt DWE4011 Brush Spring Replacement: step 4, image 1 of 1
      • Using an iFixit opening tool, remove the female terminal connecting the carbon brush wire to the male terminal.
      Ask FixBot
    5. DeWalt DWE4011 Brush Spring Replacement: step 5, image 1 of 1
      • Remove the spring by sliding it out of the center post (use an iFixit opening tool if needed).
      • When replacing the spring you need to tension it. Watch this video at 1:55 to see how.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 44
All Time: 1,802
