DeWalt DWE305 Gear Assembly Replacement
  1. DeWalt DWE305 Gear Assembly Replacement, Trigger Assembly: step 1, image 1 of 1
    • Remove the seven 3/4" Button Head Torx Security screws out of the handle with the Torx T20H bit and IFixit Precision Bit Driver.
    Ask FixBot
  2. DeWalt DWE305 Gear Assembly Replacement: step 2, image 1 of 1
    • Take the top cover off after the screws have been removed to access the trigger assembly.
    Ask FixBot
  3. DeWalt DWE305 Gear Assembly Replacement: step 3, image 1 of 1
    • Remove the single 3/4" Button Head Torx Security screw that is securing the trigger assembly using the Torx T15H bit.
    • Pull the entire trigger assembly from the handle.
    Ask FixBot
  4. DeWalt DWE305 Gear Assembly Replacement: step 4, image 1 of 1
    • Use the pointed end of the metal sludger to pry open the rectangular casing that houses the electrical contacts and wiring of the trigger assembly.
    • Be very careful not to damage any of the wiring or electrical contacts with the metal spudger
    • Assess the condition of the assembly by checking the inside of the casing for any dust, dirt, or misalignment.
    Ask FixBot
  5. DeWalt DWE305 Gear Assembly Replacement: step 5, image 1 of 1
    • Look on the back of the assembly by turning it over to the casing where the wires protrude and see if there is any damage to the cables which are connected to the motor assembly.
    Ask FixBot
  6. DeWalt DWE305 Gear Assembly Replacement: step 6, image 1 of 1
    • Look over the spring component and see if it is misaligned or warped.
    • You may have to use the flat, blunt part of the metal spudger to move the spring around and see the inside of the casing.
    Ask FixBot
  7. DeWalt DWE305 Gear Assembly Replacement: step 7, image 1 of 1
    • If any part of the trigger assembly such as electrical contacts, wiring, or the spring is damaged beyond repair, then replace the assembly and reconnect the new component to the wiring attached from the motor assembly.
    Ask FixBot
  8. DeWalt DWE305 Gear Assembly Replacement, Reciprocating Shaft: step 8, image 1 of 1
    • Use a #2 Phillips Screwdriver to remove the large black screw at the shoe of the device or the black plastic housing.
    Ask FixBot
  9. DeWalt DWE305 Gear Assembly Replacement: step 9, image 1 of 1
    • Use a Torx T20H bit and the iFixit Precision Bit Driver to remove the four 3/4" Button Head Torx Security screws from inside the shoe housing.
    Ask FixBot
  10. DeWalt DWE305 Gear Assembly Replacement: step 10, image 1 of 1
    • Once the four safety housing bolts are removed, pull the black plastic cover (the shoe) from the device.
    Ask FixBot
  11. DeWalt DWE305 Gear Assembly Replacement: step 11, image 1 of 1
    • Slide the black rubber component (the boot) off to access the reciprocating shaft assembly and metal plate.
    Ask FixBot
  12. DeWalt DWE305 Gear Assembly Replacement: step 12, image 1 of 1
    • Remove the four 1.5” Stainless Steel Button Head Torx screws that are attached to the gold metal plate. Remove the screws using a Torx T25H bit with the iFixit Precision Bit Driver.
    Ask FixBot
  13. DeWalt DWE305 Gear Assembly Replacement: step 13, image 1 of 1
    • Remove the two smaller black ¾” Button Head Torx Screws using the Torx T20H bit with the iFixit Precision Bit Driver.
    Ask FixBot
  14. DeWalt DWE305 Gear Assembly Replacement: step 14, image 1 of 1
    • Remove the gold metal plate carefully. You may need to use a flat tool to pry the cover off from the sticky surface.
    Ask FixBot
  15. DeWalt DWE305 Gear Assembly Replacement: step 15, image 1 of 1
    • After removing the plate, the reciprocating shaft is now exposed. Remove the shaft and assess it for damages or loss of lubrication.
    • If the shaft is not lubricated, apply saw lubricant generously.
    Ask FixBot
  16. DeWalt DWE305 Gear Assembly Replacement: step 16, image 1 of 1
    • Assess the front of the shaft where the blade goes. If dust or dirt are clogging the shaft, carefully clean the shaft with small cotton swabs and cleaning fluid.
    • Be aware of the blade if it is attached and take caution not to make the surface too slippery with lubricant or cleaning fluid.
    • If any part on the reciprocating shaft is damaged, then replace the reciprocating shaft with a new part.
    Ask FixBot
  17. DeWalt DWE305 Gear Assembly Replacement, Gear Assembly: step 17, image 1 of 1
    • Remove the heavy, grey metal cover that is located above the gear to access the assembly. Put aside the metal cover and carefully lift gear assembly out.
    • Evaluate the gear to ensure that no dirt or debris is jamming the gear assembly. Be sure to also evaluate the teeth of the gear, making sure no teeth have broken. Clean the gear assembly and replace gear as required.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 962
