Up to 20% off select tools
DeWalt DWD112 Field Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
102
All Time:
1,552
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
The wound wires of a field coil can fail, causing a drill to function poorly or not at all. Use this guide to replace a broken field in the DeWalt DWD112.
    1. DeWalt DWD112 Field Replacement, Power Cord: step 1, image 1 of 1
      • Remove seven TR20 Torx Security screws from the side of the drill.
      Ask FixBot
    2. DeWalt DWD112 Field Replacement: step 2, image 1 of 1
      • Remove the top cover to reveal the inside of the drill.
      • Set the top cover of the drill aside.
      Ask FixBot
    3. DeWalt DWD112 Field Replacement: step 3, image 1 of 1
      • The power cord and the trigger act as a single part and must be replaced together.
      • Using one hand grab the trigger box and with the other grab the end of the wire connecting to the trigger box and disconnect the wire.
      Ask FixBot
    4. DeWalt DWD112 Field Replacement: step 4, image 1 of 1
      • Disconnect the second connected wire from the top of the trigger box.
      Ask FixBot
    5. DeWalt DWD112 Field Replacement: step 5, image 1 of 1
      • Lift the trigger box up to reveal the bottom side.
      • Disconnect the first connected wire from the bottom of the trigger box.
      Ask FixBot
    6. DeWalt DWD112 Field Replacement: step 6, image 1 of 1
      • Disconnect the last wire from the trigger box using the same method from the previous step.
      Ask FixBot
    7. DeWalt DWD112 Field Replacement: step 7, image 1 of 1
      • After all four wires are disconnected, the trigger and power cord are separated from the drill.
      • The power cord and trigger can be set aside if further disassembly is required.
      Ask FixBot
    1. DeWalt DWD112 Field Replacement, Armature: step 8, image 1 of 1
      • Take note of the keyless chuck and the meshing of the gears.
      Ask FixBot
    2. DeWalt DWD112 Field Replacement: step 9, image 1 of 2 DeWalt DWD112 Field Replacement: step 9, image 2 of 2
      • Grab the metal chuck by the rotating spindle as if you are to tighten in a drill bit.
      • Lift the metal chuck out of its resting place and set aside.
      Ask FixBot
    3. DeWalt DWD112 Field Replacement: step 10, image 1 of 3 DeWalt DWD112 Field Replacement: step 10, image 2 of 3 DeWalt DWD112 Field Replacement: step 10, image 3 of 3
      • With your left hand, grab hold of the field, which is the large metal block with coils looped around the inside.
      • Use your other hand to take the bearing out from the end of the gear connected to the armature.
      Ask FixBot
    4. DeWalt DWD112 Field Replacement: step 11, image 1 of 3 DeWalt DWD112 Field Replacement: step 11, image 2 of 3 DeWalt DWD112 Field Replacement: step 11, image 3 of 3
      • Lift the field up once more with one hand and grab the cooling fan with the other hand and gently slide the armature out of the field.
      • The brushes will now be disconnected from the armature, meaning no current can flow from the power cord to the motor.
      Ask FixBot
    1. DeWalt DWD112 Field Replacement, Field: step 12, image 1 of 3 DeWalt DWD112 Field Replacement, Field: step 12, image 2 of 3 DeWalt DWD112 Field Replacement, Field: step 12, image 3 of 3
      • Move the black wire clear from any obstruction.
      • Repeat this step for the white wire and the red wire.
      Ask FixBot
    2. DeWalt DWD112 Field Replacement: step 13, image 1 of 2 DeWalt DWD112 Field Replacement: step 13, image 2 of 2
      • The field is disconnected from all other parts.
      • Grab the field and gently lift it out of the case.
      Ask FixBot
Author
with
Samantha McSweeney
407 Reputation
4 Guides authored
1 Guide Comment
as a recommendation aimed at some or mark with a piece of ribbon cables disconnected the trigger with the contact number that corresponds to the rearm the drill going to not reverse the change control rotation.
Jorge Diaz Viera - Reply Share
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 102
All Time: 1,552
