Up to 20% off select tools
DeWalt DW997 Trigger Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
97
All Time:
2,898
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the trigger pack. This is necessary if the battery is charged but the drill will not start or if the battery is fine but the drill will not spin.
    1. DeWalt DW997 Trigger Replacement, Trigger: step 1, image 1 of 2 DeWalt DW997 Trigger Replacement, Trigger: step 1, image 2 of 2
      • First remove the seven 21mm screws using a Torx T15 screw bit.
      • Then use a Torx T10 screw bit to remove the remaining 18mm screw.
      • After removing all of the screws, lift the cover off.
      • Do not attempt to pry the covers apart; doing so can cause the covers to crack.
      Ask FixBot
    2. DeWalt DW997 Trigger Replacement: step 2, image 1 of 1
      • Carefully remove the trigger pack by lifting the pack straight up.
      Ask FixBot
    3. DeWalt DW997 Trigger Replacement: step 3, image 1 of 1
      • The final step is to pull the wires off of the trigger by pulling the wire heads.
      • Be careful while taking off the wires as they can tear.
      Ask FixBot
Author
with
Vanessa Duran
155 Reputation
1 Guide authored
1 Guide Comment
We supply best replacement Dewalt power tool batteries at a wholesale price in Australia. Cordless drill batteries for Dewalt are producted with high test safe circle and chips that give different capacities. We pormise the replacement Dewalt batteries are 100% compatible with the orginal porducts. Full 1 year quality assurance & 30 days money back gurantee! Select cheap Dewalt cordless drill battery by models at http://www.drill-battery-au.com/bestbatt...
drillbatterycomau - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 97
All Time: 2,898
