DeWalt DW997 Speed Switch Replacement
    1. DeWalt DW997 Speed Switch Replacement, Speed Switch: step 1, image 1 of 2 DeWalt DW997 Speed Switch Replacement, Speed Switch: step 1, image 2 of 2
      • Remove seven 21 mm Torx T15 screws.
      • Remove one 18 mm Torx T10 screw.
      • After removing all screws, lift up the top yellow cover.
      • The yellow cover should easily lift up, if not, check for unscrewed screws.
      • Do not pry the two yellow covers apart, they can crack.
      Ask FixBot
    2. DeWalt DW997 Speed Switch Replacement: step 2, image 1 of 1
      • Lift the components out of the casing. These include: motor, gear assembly, trigger assembly and chuck.
      Ask FixBot
    3. DeWalt DW997 Speed Switch Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • Using the tweezers, grab the metal leg on either side of the switch and lift it outwards from the case.
      Ask FixBot
    4. DeWalt DW997 Speed Switch Replacement: step 4, image 1 of 1
      • Remove the other leg manually, it should easily come out.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 36
All Time: 2,607
