Introduction
Go to step 1 ↓If the drill does not switch rotational direction, this guide will help you disassemble and replace the switch.
There should be 7 screws that are 21 mm long, remove them with a TorxT15 bit.
There should be 1 screw that is 18 mm long, remove it with a Torx T10 bit.
