Up to 20% off select tools
DeWalt DW936 Trigger Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
91
All Time:
1,525
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to take out the trigger on the saw.
    1. DeWalt DW936 Trigger Replacement, Plastic Cover: step 1, image 1 of 1
      • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
      Ask FixBot
    2. DeWalt DW936 Trigger Replacement: step 2, image 1 of 1
      • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
      Ask FixBot
    3. DeWalt DW936 Trigger Replacement: step 3, image 1 of 1
      • Remove Allen Key.
      Ask FixBot
    4. DeWalt DW936 Trigger Replacement: step 4, image 1 of 1
      • Unscrew the black plastic knob underneath the trigger.
      Ask FixBot
    5. DeWalt DW936 Trigger Replacement: step 5, image 1 of 1
      • Grab hold of the black air filter portion and pull off.
      Ask FixBot
    6. DeWalt DW936 Trigger Replacement: step 6, image 1 of 1
      • This is what the inside of the saw looks like.
      Ask FixBot
    1. DeWalt DW936 Trigger Replacement, Trigger: step 7, image 1 of 1
      • The trigger has black and white wires coming off of it. Grip the trigger with both hands, one on the plastic trigger part and the other on the plastic by the silver metal piece.
      • Pull up.
      Ask FixBot
    2. DeWalt DW936 Trigger Replacement: step 8, image 1 of 1
      • The trigger should be able to sit freely.
      Ask FixBot
    3. DeWalt DW936 Trigger Replacement: step 9, image 1 of 2 DeWalt DW936 Trigger Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Lift off the silver metal piece using tweezers.
      • Lift off each hook. (4 corners)
      Ask FixBot
    4. DeWalt DW936 Trigger Replacement: step 10, image 1 of 1
      • Pull plastic trigger out of the black plastic casing.
      Ask FixBot
2 other people completed this guide.
Author
with
Scott Weinhardt
603 Reputation
5 Guides authored
Cal Poly, Team 8-2, Banghart Winter 2017 Member of Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Members
60 Guides authored
1 Guide Comment
Then repair trigger by stripping,cleaning,soldering and whatever else before replacing to unit as you can no longer buy the part as it is obsolete!
donald.mcguinnes - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 91
All Time: 1,525
