Up to 20% off select tools
DeWalt DW936 Boot Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
101
All Time:
1,068
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show you how to remove the boot of the saw in order to replace it.
    1. DeWalt DW936 Boot Replacement, Plastic Cover: step 1, image 1 of 1
      • Use a T-20 hexhead screw to unscrew 4 hexagonal screws surrounding the base of the black air filter. The screws are on the yellow portion.
      Ask FixBot
    2. DeWalt DW936 Boot Replacement: step 2, image 1 of 1
      • Use a T-15 hexhead screw to unscrew 5 hexagonal screws. These screws are located on the opposite side of the saw from previous step.
      Ask FixBot
    3. DeWalt DW936 Boot Replacement: step 3, image 1 of 1
      • Remove Allen Key.
      Ask FixBot
    4. DeWalt DW936 Boot Replacement: step 4, image 1 of 1
      • Unscrew the black plastic knob underneath the trigger.
      Ask FixBot
    5. DeWalt DW936 Boot Replacement: step 5, image 1 of 1
      • Grab hold of the black air filter portion and pull off.
      Ask FixBot
    6. DeWalt DW936 Boot Replacement: step 6, image 1 of 1
      • This is what the inside of the saw looks like.
      Ask FixBot
    1. DeWalt DW936 Boot Replacement, Boot: step 7, image 1 of 1
      • Use a T-15 hex head screw to unscrew the four screws located around the outside of the motor.
      Ask FixBot
    2. DeWalt DW936 Boot Replacement: step 8, image 1 of 1
      • Using an H 4.0 hex head screw, unscrew the bolt located right above the boot that is next to the motor of the saw.
      Ask FixBot
    3. DeWalt DW936 Boot Replacement: step 9, image 1 of 1
      • Pull the blade away from the body of the saw causing the blade and boot to detach.
      Ask FixBot
    4. DeWalt DW936 Boot Replacement: step 10, image 1 of 1
      • Pull the boot downwards away from the blade to detach it.
      Ask FixBot
Author
with
Scott Weinhardt
603 Reputation
5 Guides authored
Cal Poly, Team 8-2, Banghart Winter 2017 Member of Cal Poly, Team 8-2, Banghart Winter 2017
CPSU-BANGHART-W17S8G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 101
All Time: 1,068
