DeWalt DW920 Motor Replacement
    1. DeWalt DW920 Motor Replacement, Trigger: step 1, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the four screws to open up the case.
      • Ensure that the drill is unplugged and remove the battery to avoid electrical shock or accidental activation.
      Ask FixBot
    2. DeWalt DW920 Motor Replacement: step 2, image 1 of 1
      • Remove the outer housing to reveal the screws that are used to connect the outer covering of the drill.
      • Use a Phillips #2 screwdriver to remove all the screws that join the two parts of the casing.
      • Take the two halves of the housing and carefully pry them apart.
      • Make sure not to touch any parts in the interior of the screwdriver.
      Ask FixBot
    3. DeWalt DW920 Motor Replacement: step 3, image 1 of 1
      • Find and replace the old trigger. The trigger assembly should be found inside the drill.
      • The trigger is the component affixed to the motor and the wires. Loosen the wiring of the trigger carefully so that you can separate the connections of the terminals.
      • Remove the wires. Then take a picture so that you can remember how they should be connected. Pull the old trigger out from its engagement with the housing.
      Ask FixBot
    4. DeWalt DW920 Motor Replacement: step 4, image 1 of 1
      • Install the new trigger. Place the new trigger in the position within the housing where the old trigger originated from.
      • Solder the wires together by placing the terminal in the connector.
      • Check the wire connections with the help of the photo which was taken earlier, if it is necessary.
      • Make sure the trigger is locked tightly in its position.
      Ask FixBot
    5. DeWalt DW920 Motor Replacement: step 5, image 1 of 1
      • To reassemble the drill align the two halves of the housing back in their original positions, making sure that the internal parts, and in particular the trigger, are correctly positioned.
      • Put the screws back into their respective holes and fasten them with the Phillips #2 screwdriver.
      • Screw the nuts at an angle to make sure it will tightening uniformly.
      Ask FixBot
    6. DeWalt DW920 Motor Replacement: step 6, image 1 of 1
      • Test the trigger either by connecting the battery again or plugging the drill back in.
      • Pull the trigger to make the drill glide and to engage the rig. If it will not operate correctly, retract and examine its wiring and the position of the trigger.
      • If you meet any problems or have troubles with the trigger, don’t force it. Go back to the previous steps.
      Ask FixBot
    1. DeWalt DW920 Motor Replacement, Motor: step 7, image 1 of 1
      • Gently lift the motor and trigger mechanism out from the frame of the drill.
      Ask FixBot
    2. DeWalt DW920 Motor Replacement: step 8, image 1 of 1
      • Locate where the motor assembly is attached to the trigger mechanism and carefully detach the wires at their solder points.
      • Mark where the two cables were connected using masking tape.
      • Solder the new motor assembly wires to the trigger mechanism.
      Ask FixBot
  • Follow the case replacement guide for how to replace the case on the drill.
  • The trigger replacement guide is located above.
  • To reassemble the device, follow the instructions in reverse.
Stephen Rada
433 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,351
