Up to 20% off select tools
DeWalt DW660 Power Cord Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
102
All Time:
857
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The power cord can simply be replaced by opening the back of the device and unscrewing the casing. Make sure that the device is not plugged in before working on it.
    1. DeWalt DW660 Power Cord  Replacement, Power Cord: step 1, image 1 of 2 DeWalt DW660 Power Cord  Replacement, Power Cord: step 1, image 2 of 2
      • Using a T20 Torx Screwdriver, unscrew the four 19mm screws from the back casing.
      • After unscrewing, remove the back casing from the device.
      Ask FixBot
    2. DeWalt DW660 Power Cord  Replacement: step 2, image 1 of 1
      • Disconnect the wires from the switch terminals.
      Ask FixBot
    3. DeWalt DW660 Power Cord  Replacement: step 3, image 1 of 1
      • Remove the ground wire from the motor by pulling it gently.
      Ask FixBot
    4. DeWalt DW660 Power Cord  Replacement: step 4, image 1 of 1
      • Using the T20 Torx screwdriver, unscrew two screws from the bracket that holds the power cord in the casting.
      Ask FixBot
Author
with
AL25
229 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 102
All Time: 857
