DeWalt DW660 Motor Brushes Replacement
    1. DeWalt DW660 Motor Brushes Replacement, Motor Brushes: step 1, image 1 of 2 DeWalt DW660 Motor Brushes Replacement, Motor Brushes: step 1, image 2 of 2
      • Remove the four 19mm T20 Torx screws at the rear of the device.
      Ask FixBot
    2. DeWalt DW660 Motor Brushes Replacement: step 2, image 1 of 3 DeWalt DW660 Motor Brushes Replacement: step 2, image 2 of 3 DeWalt DW660 Motor Brushes Replacement: step 2, image 3 of 3
      • Remove the other part of the back casing.
      • Unplug the black and white power wires from the motor.
      Ask FixBot
    3. DeWalt DW660 Motor Brushes Replacement: step 3, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 3, image 2 of 2
      • Pinch the blue brush wire between two fingers.
      • Pull on the wire, removing them from the motor.
      Ask FixBot
    4. DeWalt DW660 Motor Brushes Replacement: step 4, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 4, image 2 of 2
      • Using the metal spudger, lift up the coil spring that holds the carbon brushes in place.
      • While the spring is lifted up, remove the carbon brush by simply sliding it out of the slot.
      Ask FixBot
    5. DeWalt DW660 Motor Brushes Replacement: step 5, image 1 of 2 DeWalt DW660 Motor Brushes Replacement: step 5, image 2 of 2
      • Repeat steps 3 and 4 to remove the other carbon brush.
      • When installing the new carbon brushes, make sure each brushes' lead wire is plugged into opposite ends of the motor.
      • Refer to the photos for visual assistance.
      Ask FixBot
Joseph Pacitto
239 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 30
All Time: 1,737
