DeWalt DW660 Bearings Replacement
  1. DeWalt DW660 Bearings Replacement, Bearings: step 1, image 1 of 1
    • Pull off the depth guide.
    • If the guide doesn't come away easily, use a twisting motion to pull it from the tool.
    Ask FixBot
  2. DeWalt DW660 Bearings Replacement: step 2, image 1 of 3 DeWalt DW660 Bearings Replacement: step 2, image 2 of 3 DeWalt DW660 Bearings Replacement: step 2, image 3 of 3
    • Hold down lock #1 to prevent the motor from spinning.
    • While holding lock #1, hold down lock #2 as well.
    • Rotate lock #2 counterclockwise to unscrew the collet nut.
    Ask FixBot
  3. DeWalt DW660 Bearings Replacement: step 3, image 1 of 1
    • Remove the collet nut and the collet from the device.
    Ask FixBot
  4. DeWalt DW660 Bearings Replacement: step 4, image 1 of 2 DeWalt DW660 Bearings Replacement: step 4, image 2 of 2
    • Unscrew the four 19mm T20 Torx screws on the motor shroud.
    • Carefully remove the shroud from the body.
    • When removing the shroud, the spring that operates lock #2 may pop out.
    Ask FixBot
  5. DeWalt DW660 Bearings Replacement: step 5, image 1 of 3 DeWalt DW660 Bearings Replacement: step 5, image 2 of 3 DeWalt DW660 Bearings Replacement: step 5, image 3 of 3
    • Unscrew the four 19mm T20 Torx screws on the side of the back end of the DW660.
    • Take apart the back two halves.
    • Using two fingers, pull the black and white power wires from the motor to completely disconnect the back half of the device.
    Ask FixBot
  6. DeWalt DW660 Bearings Replacement: step 6, image 1 of 2 DeWalt DW660 Bearings Replacement: step 6, image 2 of 2
    • Lift the coiled spring from the back of the brush using a spudger.
    • While holding the spring out of the way, use a pointed spudger to slide the carbon brush up out of the guide.
    • Slowly release the brush spring. It will sit in the brush guide.
    • Repeat this step for the second brush.
    Ask FixBot
  7. DeWalt DW660 Bearings Replacement: step 7, image 1 of 1
    • Pull the rotor out of the front of the DW660.
    • Be very careful to make sure the rotor does not collide with the stator. The stator coils or the commutator can be damaged very easily.
    Ask FixBot
  8. DeWalt DW660 Bearings Replacement: step 8, image 1 of 1
    • Remove the snap ring from the bearing by using snap ring pliers.
    • This will take some force and the snap ring will act as a spring, so be careful to make sure the ring does not fly off the pliers.
    Ask FixBot
  9. DeWalt DW660 Bearings Replacement: step 9, image 1 of 1
    • Pull the black plastic bearing block off of the motor shaft.
    • Remove the ball bearing from the bearing block.
    Ask FixBot
  10. DeWalt DW660 Bearings Replacement: step 10, image 1 of 2 DeWalt DW660 Bearings Replacement: step 10, image 2 of 2
    • Remove the rubber cap from the bearing.
    • Use the bearing puller to remove the bearing from the shaft.
    • When installing the new bearings, it may help to use a small hammer and a hollow circular pipe with the same outer diameter as the inner ring of the bearing.
    Ask FixBot
Ryan Owen Rheaume
405 Reputation
1 Guide authored
2 Guide Comments
What size bearing does it take?
James Armstrong - Reply Share
A 608-2RS and an R8-RS. I found the 608 through a reference for the DeWalt part number 330003-03. When zooming in on the step 8 picture, you can see "R8RS" on the bearing shield.
knipwim - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 49
All Time: 1,280
