DeWalt DCF887B Type 3 Spring Replacement
    1. DeWalt DCF887B Type 3 Spring Replacement, Spring: step 1, image 1 of 1
      • Place the picker inside the first washer and lever it out of place.
      • Use a bit of strength to ensure that the collar doesn’t click back in the same place.
      Ask FixBot
    2. DeWalt DCF887B Type 3 Spring Replacement: step 2, image 1 of 2 DeWalt DCF887B Type 3 Spring Replacement: step 2, image 2 of 2
      • Once you pop out the first washer with a slight gap in it, called a "hog ring," a plain washer will follow.
      Ask FixBot
    3. DeWalt DCF887B Type 3 Spring Replacement: step 3, image 1 of 1
      • Remove the collar by grabbing the outer rim and pulling it out gently with your fingers.
      • Once you remove the collar, place it on the side of the table with the shortest end pointing upwards.
      Ask FixBot
    4. DeWalt DCF887B Type 3 Spring Replacement: step 4, image 1 of 1
      • Remove the steel ball by popping it out with the picker, or ideally, grabbing it with a magnetic tool.
      • Use minimal force when popping the steel ball out to ensure that it doesn’t fly away.
      • Set the steel ball somewhere it won't roll away.
      Ask FixBot
    5. DeWalt DCF887B Type 3 Spring Replacement: step 5, image 1 of 1
      • Grab the broken spring and pull it out gently.
      • You might have to wiggle the spring back-and-forth during removal.
      Ask FixBot
    6. DeWalt DCF887B Type 3 Spring Replacement: step 6, image 1 of 1
      • Replace the steel ball.
      • Align the crook in the spring with the steel ball's hole in the spindle to install the new spring.
      • Compress the spring right back through the middle of the steel ball frame.
      • Make sure the steel ball is tensioned by the spring.
      Ask FixBot
    7. DeWalt DCF887B Type 3 Spring Replacement: step 7, image 1 of 1
      • Attach the collar over the spring.
      • Apply light pressure on the spring with your left hand to pop the collar back on top.
      Ask FixBot
    8. DeWalt DCF887B Type 3 Spring Replacement: step 8, image 1 of 1
      • With the collar facing up, add the plain washer back into the center of the collar, then the hog ring.
      • Press down on the hog ring along with the collar until you hear it "click" into place.
      Ask FixBot
Your impact driver should now be fully-functional!
2 Guide Comments
Getting the hog ring back on is difficult. Is there a tool, besides picks, to help with this?
BRUCE BROWN - Reply Share
Nope, patience and diligence. Get one side of the ring completely seated and then slide slowly around the inside of it so widen it as you push down. 2 small drivers can help
eric arendale (ericofcourse) - Reply Share
Past 24 Hours: 7
Past 7 Days: 48
Past 30 Days: 165
All Time: 6,376
