Up to 20% off select tools
DeWalt D28110 Power Switch Replacement
Views: 7.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
125
All Time:
7,258
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The power switch is the combination of two pieces working together, the mechanical switch and the electronic switch. If the switch is problematic, you may want to replace one or both of these components.
    1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Gear Case: step 1, image 1 of 1
      • Using the T-15 screwdriver, remove the four 22-mm torx screws on the gear case.
      • Unplug the grinder before any disassembly.
      Ask FixBot
    2. DeWalt D28110 Power Switch Replacement: step 2, image 1 of 2 DeWalt D28110 Power Switch Replacement: step 2, image 2 of 2
      • Pull out the gear case.
      Ask FixBot
    1. DeWalt D28110 Power Switch Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: step 3, image 1 of 1
      • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
      Ask FixBot
    2. DeWalt D28110 Power Switch Replacement: step 4, image 1 of 1
      • Use the edge of the spudger to loosen and remove the back panel.
      Ask FixBot
    3. DeWalt D28110 Power Switch Replacement: step 5, image 1 of 1
      • Remove the single 20-mm torx screw holding the rear panel in place.
      Ask FixBot
    4. DeWalt D28110 Power Switch Replacement: step 6, image 1 of 1
      • Pull back the rear side of the back panel.
      Ask FixBot
    1. DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 1 of 3 DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 2 of 3 DeWalt D28110 Power Switch Replacement, Power Switch: step 7, image 3 of 3
      • There is an inner plastic guard behind the motor shaft.
      • Unscrew the four screws at each corner.
      • The guard should pull out with a good firm tug.
      Ask FixBot
    2. DeWalt D28110 Power Switch Replacement: step 8, image 1 of 3 DeWalt D28110 Power Switch Replacement: step 8, image 2 of 3 DeWalt D28110 Power Switch Replacement: step 8, image 3 of 3
      • Just behind the inner guard is the button slide.
      • Use needle nose pliers to pinch and push the button's flanges together, and out of the slot.
      Ask FixBot
    3. DeWalt D28110 Power Switch Replacement: step 9, image 1 of 3 DeWalt D28110 Power Switch Replacement: step 9, image 2 of 3 DeWalt D28110 Power Switch Replacement: step 9, image 3 of 3
      • Using the J-1 screwdriver, unscrew the power cord wires from the red switch box (located in the back of the grinder).
      Ask FixBot
    4. DeWalt D28110 Power Switch Replacement: step 10, image 1 of 2 DeWalt D28110 Power Switch Replacement: step 10, image 2 of 2
      • Disconnect the motor wires from the other side of the switch box.
      • They wires are connected as a sleeve to the flat pin out of the switch box. A firm pull should do it.
      Ask FixBot
3 other people completed this guide.
Author
with
Kean Wee
546 Reputation
4 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
84 Guides authored
1 Guide Comment
Very clear and concise guide with relevent pictures. Very well done, thank you
Michael Creel - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 125
All Time: 7,258
