DeWalt D28110 Brush and Spring Replacement
  1. DeWalt D28110 Brush and Spring Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: step 1, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
    Ask FixBot
  2. DeWalt D28110 Brush and Spring Replacement: step 2, image 1 of 1
    • Use the edge of the spudger to loosen and remove the back panel.
    Ask FixBot
  3. DeWalt D28110 Brush and Spring Replacement: step 3, image 1 of 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
    Ask FixBot
  4. DeWalt D28110 Brush and Spring Replacement: step 4, image 1 of 1
    • Pull back the rear side of the back panel.
    Ask FixBot
  5. DeWalt D28110 Brush and Spring Replacement, Brush and Spring: step 5, image 1 of 2 DeWalt D28110 Brush and Spring Replacement, Brush and Spring: step 5, image 2 of 2
    • Gently pull to disconnect brush connector.
    Ask FixBot
  6. DeWalt D28110 Brush and Spring Replacement: step 6, image 1 of 2 DeWalt D28110 Brush and Spring Replacement: step 6, image 2 of 2
    • Use the edge of the spudger to slide the spring off its post.
    Ask FixBot
  7. DeWalt D28110 Brush and Spring Replacement: step 7, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to gently remove the brush and cable.
    Ask FixBot
Kean Wee
522 Reputation
4 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 25
All Time: 2,942
