DeWalt D28110 Brush Arm Replacement
  1. DeWalt D28110 Brush Arm Replacement, Disassembling DeWalt D28110 Back Panel Disassembly: step 1, image 1 of 1
    • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
    • Unplug the grinder before any disassembly.
    Ask FixBot
  2. DeWalt D28110 Brush Arm Replacement: step 2, image 1 of 1
    • Use the edge of the spudger to loosen and remove the back panel.
    Ask FixBot
  3. DeWalt D28110 Brush Arm Replacement: step 3, image 1 of 1
    • Remove the single 20-mm torx screw holding the rear panel in place.
    Ask FixBot
  4. DeWalt D28110 Brush Arm Replacement: step 4, image 1 of 1
    • Pull back the rear side of the back panel.
    Ask FixBot
  5. DeWalt D28110 Brush Arm Replacement, Brush Arm: step 5, image 1 of 1
    • Using the T-6 screwdriver, unscrew torx screw holding the arm in place.
    Ask FixBot
  6. DeWalt D28110 Brush Arm Replacement: step 6, image 1 of 1
    • Gently remove the arm from the assembly.
    Ask FixBot
2 other people completed this guide.
Kean Wee
522 Reputation
4 Guides authored
Cal Poly, Team 18-6, Maness Winter 2015 Member of Cal Poly, Team 18-6, Maness Winter 2015
CPSU-MANESS-W15S18G6
5 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 2,917
