DeWalt D26451 Power Switch Replacement
    1. DeWalt D26451 Power Switch Replacement, Power Cord: step 1, image 1 of 1
      • Please wear safety glasses while completing this guide.
      • Remove screws (3) from cap by using the T20 torx attachment and unscrewing in a leftward motion.
      Ask FixBot
    2. DeWalt D26451 Power Switch Replacement: step 2, image 1 of 1
      • Gently pry the cap off using your fingers or spudger tool.
      Ask FixBot
    3. DeWalt D26451 Power Switch Replacement: step 3, image 1 of 1
      • Once cap is off, expose and locate the power cord mounting bracket and remove the 2 screws holding the wire down by using the T15 torx attachment. Once the cord is loose, pull the connectors out
      Ask FixBot
    4. DeWalt D26451 Power Switch Replacement: step 4, image 1 of 1
      • Loosen the white and black wire terminals
      Ask FixBot
    5. DeWalt D26451 Power Switch Replacement: step 5, image 1 of 1
      • Insert new power cord terminals and tighten down
      • Do not over-tighten
      Ask FixBot
    1. DeWalt D26451 Power Switch Replacement, Power Switch: step 6, image 1 of 1
      • Remove screws (3) from the cap using a T20 torx attachment by unscrewing in a leftward motion
      Ask FixBot
    2. DeWalt D26451 Power Switch Replacement: step 7, image 1 of 1
      Ask FixBot
    3. DeWalt D26451 Power Switch Replacement: step 8, image 1 of 1
      • Once the cap is removed, the switch and connectors should be exposed
      Ask FixBot
    4. DeWalt D26451 Power Switch Replacement: step 9, image 1 of 1
      • Remove both connectors from the switch
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 2,016
