DeLonghi Magnifica - Lubricate the brewing unit
    1. DeLonghi Magnifica - Lubricate the brewing unit, Initial situation: step 1, image 1 of 3 DeLonghi Magnifica - Lubricate the brewing unit, Initial situation: step 1, image 2 of 3 DeLonghi Magnifica - Lubricate the brewing unit, Initial situation: step 1, image 3 of 3
      • Remove the brewing unit from the machine as for cleaning by pressing the two red levers
      • Initial situation Remove the brewing unit from the machine as for cleaning by pressing the two red levers. The main problem is that the piston with the filter (orange) is very difficult to move. This can be recognized, for example, by the fact that the grounds do not fall into the container but in a different direction.
      Ask FixBot
    2. DeLonghi Magnifica - Lubricate the brewing unit, Remove the clamp: step 2, image 1 of 2 DeLonghi Magnifica - Lubricate the brewing unit, Remove the clamp: step 2, image 2 of 2
      • Use a spatula (metal spudger) to loosen the clamp (green) that is holding the piston.
      Ask FixBot
    3. DeLonghi Magnifica - Lubricate the brewing unit, Remove the piston: step 3, image 1 of 3 DeLonghi Magnifica - Lubricate the brewing unit, Remove the piston: step 3, image 2 of 3 DeLonghi Magnifica - Lubricate the brewing unit, Remove the piston: step 3, image 3 of 3
      • The inner part marked in orange an be removed completely
      • Then the actual piston with the strainer and rubber seals can be pushed out on the other side
      Ask FixBot
    4. DeLonghi Magnifica - Lubricate the brewing unit, Lubricate the piston: step 4, image 1 of 1
      • The piston (especially the rubber seals) can now be lubricated with a food-safe grease.
      • Then reassemble everything
      Ask FixBot
    5. DeLonghi Magnifica - Lubricate the brewing unit, Disassemble the rest: step 5, image 1 of 2 DeLonghi Magnifica - Lubricate the brewing unit, Disassemble the rest: step 5, image 2 of 2
      • The rest of the brewing unit can also be easily disassembled by loosening all screws
      • The piston is even easier to install if you loosen the two screws marked in green
      • To release the part with the two red latches or locks, there is a screw hidden under the coffee spout (orange
      Ask FixBot
    6. DeLonghi Magnifica - Lubricate the brewing unit, Removing the scraper lever: step 6, image 1 of 2 DeLonghi Magnifica - Lubricate the brewing unit, Removing the scraper lever: step 6, image 2 of 2
      • The scraper lever can also be easily removed and replaced. To do this, simply remove the screw on the axle.
      • When reassembling, one end of the spring underneath must be inserted back into the hole (yellow ring) and the other end must be inserted into the scraper before it is correctly guided back over the locking pin or stop pin (marked with a red circle).
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Peter Scholl
2,003 Reputation
7 Guides authored
AEG-Make&Repair AG Member of AEG-Make&Repair AG
Local Repair Groups
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 17
Past 7 Days: 124
Past 30 Days: 603
All Time: 4,197
