DeLonghi ETAM series top removal
    1. DeLonghi ETAM series top removal, DeLonghi ETAM Opening side panels: step 1, image 1 of 2 DeLonghi ETAM series top removal, DeLonghi ETAM Opening side panels: step 1, image 2 of 2
      • Disconnect the power plug and remove the power cord from the device.
      • Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
      • Unscrew the two Phillips screws
      • The Phillips screw under the water tank can remain.
      Ask FixBot
    2. DeLonghi ETAM series top removal: step 2, image 1 of 2 DeLonghi ETAM series top removal: step 2, image 2 of 2
      • The bean compartment flap must be removed. It is latched on the left and right, the latch is held under tension by a spring. Compress the spring until the catch is free and lift off the flap.
      Ask FixBot
    3. DeLonghi ETAM series top removal: step 3, image 1 of 3 DeLonghi ETAM series top removal: step 3, image 2 of 3 DeLonghi ETAM series top removal: step 3, image 3 of 3
      • There is a plastic cover strip under the flap. It is only latched in place. Release it with a flat tool and lift it out.
      Ask FixBot
    4. DeLonghi ETAM series top removal: step 4, image 1 of 2 DeLonghi ETAM series top removal: step 4, image 2 of 2
      • Lift the back side up and put it aside.
      Ask FixBot
    5. DeLonghi ETAM series top removal: step 5, image 1 of 2 DeLonghi ETAM series top removal: step 5, image 2 of 2
      • The side covers are still attached to the back with two screws. They are located under a cover strip that is only snapped in place. Take off the cover strip and put it aside.
      • Unscrew the two Phillips screws.
      Ask FixBot
    6. DeLonghi ETAM series top removal: step 6, image 1 of 2 DeLonghi ETAM series top removal: step 6, image 2 of 2
      • Push the left side panel back about 1 cm. It often jams strongly and you have to help it with a plastic opening tool.
      • Remove the left side panel.
      Ask FixBot
    7. DeLonghi ETAM series top removal: step 7, image 1 of 1
      • The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
      • Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
      Ask FixBot
    1. DeLonghi ETAM series top removal, DeLonghi ETAM series top removal: step 8, image 1 of 2 DeLonghi ETAM series top removal, DeLonghi ETAM series top removal: step 8, image 2 of 2
      • Some devices have a warming plate. Disconnect the flat plugs on the green/yellow protective earth conductors.
      • When reassembling, don't forget to put them back on.
      Ask FixBot
    2. DeLonghi ETAM series top removal: step 9, image 1 of 2 DeLonghi ETAM series top removal: step 9, image 2 of 2
      • The top is fixed with screws on the left and right, depending on the type. Unscrew them.
      • Now the top can be gently lifted off.
      • Depending on the type, it is shaped differently. Some have the control panel far to the rear. Leave it for now, it is connected with cables.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
338,920 Reputation
311 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,178
