DeLonghi ETAM Opening side panels
Views: 3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
132
All Time:
2,968
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
For most repairs, the device must be opened. These instructions show how to remove the side panels.
    1. DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: step 1, image 1 of 2 DeLonghi ETAM Opening side panels, DeLonghi ETAM Opening side panels: step 1, image 2 of 2
      • Disconnect the power plug and remove the power cord from the device.
      • Remove all coffee beans. Remove all attachments such as drip tray, milk frother and water tank. Open the service door and remove the brew group.
      • Unscrew the two Phillips screws
      • The Phillips screw under the water tank can remain.
      Ask FixBot
    2. DeLonghi ETAM Opening side panels: step 2, image 1 of 2 DeLonghi ETAM Opening side panels: step 2, image 2 of 2
      • The bean compartment flap must be removed. It is latched on the left and right, the latch is held under tension by a spring. Compress the spring until the catch is free and lift off the flap.
      Ask FixBot
    3. DeLonghi ETAM Opening side panels: step 3, image 1 of 3 DeLonghi ETAM Opening side panels: step 3, image 2 of 3 DeLonghi ETAM Opening side panels: step 3, image 3 of 3
      • There is a plastic cover strip under the flap. It is only latched in place. Release it with a flat tool and lift it out.
      Ask FixBot
    4. DeLonghi ETAM Opening side panels: step 4, image 1 of 2 DeLonghi ETAM Opening side panels: step 4, image 2 of 2
      • Lift the back side up and put it aside.
      Ask FixBot
    5. DeLonghi ETAM Opening side panels: step 5, image 1 of 2 DeLonghi ETAM Opening side panels: step 5, image 2 of 2
      • The side covers are still attached to the back with two screws. They are located under a cover strip that is only snapped in place. Take off the cover strip and put it aside.
      • Unscrew the two Phillips screws.
      Ask FixBot
    6. DeLonghi ETAM Opening side panels: step 6, image 1 of 2 DeLonghi ETAM Opening side panels: step 6, image 2 of 2
      • Push the left side panel back about 1 cm. It often jams strongly and you have to help it with a plastic opening tool.
      • Remove the left side panel.
      Ask FixBot
    7. DeLonghi ETAM Opening side panels: step 7, image 1 of 1
      • The right side panel is removed in the same way, but the service hatch is a bit obstructive. Open it first and push the side panel back a few millimeters. This is often difficult and you will need a plastic lever tool.
      • Close the flap again and push the sides further back. It is a bit tricky and you have to work carefully. Lift out the side panel.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
shingle is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
344,407 Reputation
317 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 132
All Time: 2,968
