DeLonghi ECAM series pump replacement
    1. DeLonghi ECAM series pump replacement, DeLonghi ECAM back panel removal: step 1, image 1 of 1
      • Unplug the power cord!
      • Remove all attachments such as water tank, pulp drawer, brew group.
      • Turn the machine with the back facing you.
      • Remove five Torx T20 security screws.
      • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
      Ask FixBot
    2. DeLonghi ECAM series pump replacement: step 2, image 1 of 2 DeLonghi ECAM series pump replacement: step 2, image 2 of 2
      • Lift out the back.
      • The following components are immediately visible:
      • grinder
      • pump
      • flowmeter
      Ask FixBot
    1. DeLonghi ECAM series pump replacement, DeLonghi ECAM Series left side panel: step 3, image 1 of 3 DeLonghi ECAM series pump replacement, DeLonghi ECAM Series left side panel: step 3, image 2 of 3 DeLonghi ECAM series pump replacement, DeLonghi ECAM Series left side panel: step 3, image 3 of 3
      • Push the side panel back about 1.5 cm.
      • Lift off the panel.
      • The following compononents are exposed:
      • Heater
      • Expansion chamber
      • Gear drive
      • Steam valve
      Ask FixBot
    1. DeLonghi ECAM series pump replacement, Pump: step 4, image 1 of 1
      • The pump is located on the back of the device. It is supported by a spring and a rubber surround.
      Ask FixBot
    2. DeLonghi ECAM series pump replacement: step 5, image 1 of 2 DeLonghi ECAM series pump replacement: step 5, image 2 of 2
      • Pull out the metal clip at the outlet of the mebrand damper.
      • Pull off the pressure hose. There is an O-ring at the end of the hose, which is usually stuck in the connection. Replace it during reassembly.
      Ask FixBot
    3. DeLonghi ECAM series pump replacement: step 6, image 1 of 2 DeLonghi ECAM series pump replacement: step 6, image 2 of 2
      • Pull the pump out to the rear.
      • Unscrew the diaphragm damper counterclockwise.
      Ask FixBot
    4. DeLonghi ECAM series pump replacement: step 7, image 1 of 1
      • Disconnect the two flat connectors and the thermal protection switch.
      Ask FixBot
    5. DeLonghi ECAM series pump replacement: step 8, image 1 of 3 DeLonghi ECAM series pump replacement: step 8, image 2 of 3 DeLonghi ECAM series pump replacement: step 8, image 3 of 3
      • Detach the silicone hose on the left side and pull out the pump completely.
      • Remove the spring and the hose on the left side.
      • Detach the rubber holder.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
341,556 Reputation
315 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 80
Past 30 Days: 366
All Time: 9,482
