DeLonghi ECAM Series power board replacement
    1. DeLonghi ECAM Series power board replacement, DeLonghi ECAM back panel removal: step 1, image 1 of 1
      • Unplug the power cord!
      • Remove all attachments such as water tank, pulp drawer, brew group.
      • Turn the machine with the back facing you.
      • Remove five Torx T20 security screws.
      • A small hurdle: These screws have a pin in the middle, so the screwdriver must have a hole.
      Ask FixBot
    2. DeLonghi ECAM Series power board replacement: step 2, image 1 of 2 DeLonghi ECAM Series power board replacement: step 2, image 2 of 2
      • Lift out the back.
      • The following components are immediately visible:
      • grinder
      • pump
      • flowmeter
      Ask FixBot
    1. DeLonghi ECAM Series power board replacement, Replace power board: step 3, image 1 of 1
      • Also slide the cover - if not already done - on the water tank side backwards and remove it.
      Ask FixBot
    2. DeLonghi ECAM Series power board replacement: step 4, image 1 of 1
      • The power board is located under the cover. It is fixed with four screws in the corners and connected with a lot of cables.
      • Move the cables a bit to the side and unscrew the four Phillips screws in the corners.
      Ask FixBot
    3. DeLonghi ECAM Series power board replacement: step 5, image 1 of 2 DeLonghi ECAM Series power board replacement: step 5, image 2 of 2
      • The cables have many different connectors and can almost not be confused. Make a special note of where the flat connectors are connected.
      • The flat connectors can be disconnected more easily if you lift the cover in the corner of the device to the side.
      • Lift the board out a few centimeters.
      • Carefully loosen all connections. Some are secured with latches that you have to push away first.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
342,975 Reputation
315 Guides authored
1 Guide Comment
Just wanted to say thanks for posting this; successfully fixed my machine today. The cables are an absolute pita to get off the old board and I did need tweezers and needle point pliers.
Dave Morris - Reply Share
Past 24 Hours: 2
Past 7 Days: 29
Past 30 Days: 203
All Time: 3,822
