This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
DeLonghi Coffee Maker grindstones replacement
    1. DeLonghi  Coffee Maker grindstones replacement, Grindstones: step 1, image 1 of 3 DeLonghi  Coffee Maker grindstones replacement, Grindstones: step 1, image 2 of 3 DeLonghi  Coffee Maker grindstones replacement, Grindstones: step 1, image 3 of 3
      • If the bean hopper is still attached, it must be removed.
      • Use a pointed tool to remove the cap on the adjustment dial.
      Ask FixBot
    2. DeLonghi  Coffee Maker grindstones replacement: step 2, image 1 of 3 DeLonghi  Coffee Maker grindstones replacement: step 2, image 2 of 3 DeLonghi  Coffee Maker grindstones replacement: step 2, image 3 of 3
      • There is a Phillips screw underneath. Unscrew it.
      • Note the position and pull the dial upwards.
      • Pull the bean container upwards.
      • On some models, there are two more Phillips screws in the bean hopper.
      Ask FixBot
    3. DeLonghi  Coffee Maker grindstones replacement: step 3, image 1 of 3 DeLonghi  Coffee Maker grindstones replacement: step 3, image 2 of 3 DeLonghi  Coffee Maker grindstones replacement: step 3, image 3 of 3
      • Mark the settings of the wheels with a pencil.
      • Use a spatula to loosen the two detents on the sides.
      • Pull off the red silicone seal.
      Ask FixBot
    4. DeLonghi  Coffee Maker grindstones replacement: step 4, image 1 of 3 DeLonghi  Coffee Maker grindstones replacement: step 4, image 2 of 3 DeLonghi  Coffee Maker grindstones replacement: step 4, image 3 of 3
      • Lift off the white plastic ring.
      • Turn the white ring with the ring gear counterclockwise as far as it will go.
      • The grinding ring is free and you can lift it out upwards.
      Ask FixBot
    5. DeLonghi  Coffee Maker grindstones replacement: step 5, image 1 of 1
      • The grinding ring can be completely removed from the plastic holder. To do this, lift the three detents to the side and push the ring out.
      • The ring has three flattened sides. Unfortunately, such a ring is not commercially available anywhere. If it is still good, you may be able to use it in another mill.
      Ask FixBot
    6. DeLonghi  Coffee Maker grindstones replacement: step 6, image 1 of 2 DeLonghi  Coffee Maker grindstones replacement: step 6, image 2 of 2
      • The grinding cone is fastened with a Torx T20 screw with left-hand thread.
      • Unscrew the screw clockwise, i.e. the wrong way round.
      • When assembling, make sure that the screw with its fastening part fits exactly into the intended groove.
      Ask FixBot
    7. DeLonghi  Coffee Maker grindstones replacement: step 7, image 1 of 2 DeLonghi  Coffee Maker grindstones replacement: step 7, image 2 of 2
      • Carefully lift the grinding cone upwards.
      • This grinding cone is the same as on the Jura and can now be replaced.
      • There are three metal balls on springs under the grinding cone. They are stuck in three sleeves in the plastic driver. Make sure that none of these parts get lost.
      • Lift the driver up and out.
      • Now you can clean all parts thoroughly.
      • When reassembling, make sure that the metal balls fit into the corresponding recesses in the cone.
      Ask FixBot
Work through the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
90%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
341,556 Reputation
315 Guides authored
4 Guide Comments
Hallo, ist es moeglich, den Mitnehmer aus Kunsstoff incl. der drei Huelsen als Ersatzteil zu bekommen?
danke im voraus
Schneiderei - Reply Share
Normalerweise nicht, DeLonghi verkauft leider keine Einzelteile des Mahlwerks. Aber irgendjemand hat doch bestimmt ein altes Mahlwerk rumliegen, ich z.B. :-) (schau in mein Profil)
VauWeh - Reply Share
المطحنة تشتغل 40ثانيه
MAESTOSA - Reply Share
That's too much. Perhaps you can find a used board for a replacement?
Past 24 Hours: 15
Past 7 Days: 84
Past 30 Days: 304
All Time: 8,470
