Community-Contributed Guide
Introduction
Go to step 1 ↓These instructions show how to replace the grinding burr for a DeLonghi cone grinder. The burr are very similar to those of Jura (and similar in construction). Unfortunately, however, the grinding ring has three flattened sides and is nowhere to be found. The cone burr from Jura fits, though. So the instructions are only of limited use, e.g. to get spare parts from a grinder with a defective motor, or if the replacement of the cone burr is already enough. Otherwise, the grinder must be replaced completely, it is not so much more expensive than the burr set (eg from Jura) itself. In the meantime, burr sets from other suppliers are being offered. Compare the spare part and make sure that the ring burr has three flattened sides (not two, as e.g. with Jura).
Also take a look at our wiki DeLonghi grinder jams.
Tools
If the bean hopper is still attached, it must be removed.
Use a pointed tool to remove the cap on the adjustment dial.
Work through the steps in reverse order to reassemble your device.
3 other people completed this guide.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
4 Guide Comments
Hallo, ist es moeglich, den Mitnehmer aus Kunsstoff incl. der drei Huelsen als Ersatzteil zu bekommen?
danke im voraus
